Question about Ovens
How to fit a front panel to a dh53ck
Looking for details of how to replace the front fascia on a hotpoint cucina dh53ck. I have a replacement fascia.
2 Suggested Answers
SOURCE: Stoves E2H600- lighting behind fascia
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Posted on Jun 24, 2011
How do I remove the clock/timer assembly that is integrated into the glass fascia panel of an Electrolux oven EOB63100K? The new part I have purchased is complete with its own small fascia panel
Open the oven door and remove the two screws. Pull out the oven and disconnect it from the power source.
To replace the timer you should to remove the two upper cabinets of housing of the oven.
Dado
Feb 18, 2015 | Electrolux Ovens
Top oven not working in a hotpoint dh53ck
change the thermostat and check.
Nov 07, 2013 | Ovens
Knobs on front of oven
Google "Smeg parts"
Find your local service agent.
Oct 17, 2013 | Smeg Cucina SE375 SS Oven
Front cool touch facia model Neff | B1262W0GB/01 | Built-in Oven | white needs to be replaced please help source and how to fit
Part number is 289510, I have checked with Neff and unfortunately is is no longer available. The part was 230 quid!!! and that was just for the front portion as the fascia comes in three parts. I have added the link so you can check yourself, just enter B1262W0GB/01 in the search box and click on Page 2
http://www.neff-eshop.com/eshop/neff/gb/sparepartsearch1.htm
Feb 19, 2013 | Neff Ovens
Stoves E2H600- lighting behind fascia panel has gone off so cannot now see what temperature settings are! How do you remove the fascia panel to access and replace defective lighting unit/s? Many thanks,...
Jun 22, 2011 | Stoves Ovens
How can I remove the fascia panel from my Neff double oven? I have a Neff U1552 oven. The display-film strip showing the temperature for the fan oven broke. I have bought a replacement part from Neff and...
did you manage to fix your strip, i have the same problem, all4 strips have broken in the last 6 months on my U1552. how much was the replacement?
Jan 02, 2011 | Neff Ovens
How do you fit an oven door to a Hotpoint BD81P oven? My hinges need replacing ?
Go to
WWW.YOUTUBE.CO.UK
In the search box enter---FITTING OVEN DOOR HINGES
You will find some very informative videos on how to fit the hinges.
Dec 04, 2010 | Hotpoint Ovens
The inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
Need to replace baking unit on Hotpoint range
Difficult is a relative question, I don't think it's very difficult though.
**First-Unplug the unit from the wall, or shut off any power to the unit.**
All you should need is a robertson screwdriver, perhaps a philips and slotted depending on the existing screw heads (square,star and flat) Remove the two screws at the back of the element bracket. Once they are removed, carefully pull the element a couple of inches from the oven cavity, there will be 2 wires connected to it. Hopefully the wires will be long enough to allow you to do this from the front, if not you'll need to remove the back panel of the range. If you have wires long enough you can proceed to remove them and install the new element in the reverse procedure.
You may also require a pair of pliers as well to remove/install the screws on the bake element, hold the connector with the pliers, and turn the screw with the driver so as not to twist the connector in a circle and hence ruining your new element.
*Note; inspect the connections of the wires to the element, if they look burnt, cracked, or just barely hanging on, replace them. you'll need to purchase (if you haven't already) a wire stripper/crimper and some new fittings. Make sure the new fittings/connectors are of the "hi-temp" (usually chrome/nickle plated) variety. Regular metal connector's will fatigue in a short time, relative again to how often the bake is used.
hope that helps, let me know if you need any further assistance.
Good Luck :)
Oct 23, 2009 | Hotpoint Ovens
Ovens Logo
19 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
