Question about Garden
Zetor tractor 4341 super forward and reverse lever
  • 95 Answers
SOURCE: Loss on drive on Poulan Lawn Tractor
Check to make sure the belt is not broken or did not come off the transaxle pulley, you can check by removing battery from under seat and pulling battery box out to examine top of transaxle,Pay close attention to the wire belt guide on the rh side of the transaxle pulley it should be close to the backside of the belt after it is reinstalled.If you recently may have removed the rear tire make sure the square key on the axle didn't drop out.Is the tractor a hydrostat drive? If so make sure brake is not stuck on,if it was it would make a grinding noise.
Posted on Jul 30, 2009
  • 2841 Answers
SOURCE: tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Posted on Sep 01, 2009
mickey813
  • 472 Answers
SOURCE: my craftsman lawn tractor has a 42 in. deck, w/21
YOUR TRANS IS BAD
Posted on Oct 02, 2009
mickey813
  • 472 Answers
SOURCE: 24 hp. garden tractor goes in reverse but not forward
SOUNDS LIKE ITS TIME FOR A NEW TRNS AXEL
Posted on Oct 30, 2009
wireguy212
  • 1627 Answers
SOURCE: John deer 6400 Shuttle shift will not engauge
You have the old style reverser which has been replaced by one that beeps instead of kicking out.These are a known problem with Deere and that is why you can't buy them anymore.The fact that you can hold it in yourself indicates that the enable solenoid and the forward and reverse solenoid are ok and all safety switches are working.You need to replace the reversrer.
Posted on Feb 05, 2010
It will run backwards but not forward
If you are able to move in reverse but not forward, you need to adjust the levers. First you will need to elevate the rear wheels and set the neutral. This will then allow you to set the levers for proper forward and reverse movements.
May 03, 2015 | Husqvarna Zero Turn Mower Z5426
My lawn mower model 425613x8a only drives in reverse what is my problem and how do I fix it?
I'am not to familiar,with this model number,of this tractor. But i do know that there is a safety switch,installed below the shift lever. Usually this switch,controls the neural,forward and reverse for your tractor. I suspect the forward motion contact is bad in the switch itself. You will have to remove the motion drive assembly and purchase a new switch,sometimes the safety switch is part of the whole assembly. You can find this assembly,under the shifting lever under the tractor,s floor. It could be on the right side or the left side depending on the location of the shifting lever.Sincerely,Brad Locke DTD 12/03/15
Sep 07, 2013 | Sears Garden
Mower starts and runs but won't move forward or reverse and brakes don't work.
If your transmission is automatic on the drive axle, look for a small lever inside the frame and below the seat. It can be hard to find the first time. This lever disengages the drive inside the auto gearbox so the mower can be pushed by hand. If the lever is not not moved, pushing the mower also tries to turn over the engine making it impossible to move. With the lever moved accidentally the drive is disengaged and the mower won't move in either direction. The lever operates a flexible cable that comes out from the auto transmission.
Dec 12, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Hst pedel is limp- no forward or reverse
is the lever on the rear in the released position the one you pull to push it did the rod fall off
Apr 28, 2012 | Garden
John deer 6400 Shuttle shift will not engauge . I can here a relay activat in the fuse panel. If I hold the lever up the tractor will move forward and the same for reverse. But the lever will not stay...
Feb 05, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Mar 23, 2009 | Garden
Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Oct 14, 2008 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
