Question about Canon MP560 All-In-One InkJet Printer
Type of printhead incorrect - Canon MP560 All-In-One InkJet Printer
Tinteiros
  • 85 Answers
SOURCE: CANON MP830 all in one is sayin" the type of printhead is incorrectn Install the correct Printhead."
Hi follow the instructions as above...
ie Remove inks and print head...
But instead...
Whilst Canon print head is out...
Use cotton wool and alcohol and clean electrical contacts on back of print head and where they make contact inside printer.
Then install print head and inks and test.
If it does not work you may need to replace print head.
Posted on May 10, 2008
  • 2692 Answers
SOURCE: The Type of Printhead is
Are you sure that the driver that you have installed is the one for the version of windows that you are using?Either way get updated drivers and install same to see if that fixs the problem..
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7994
Posted on Jan 01, 2009
  • 1244 Answers
SOURCE: the type of printhead is incorrect, install the
go into the printer properties and go to advance tab and do a realignment of the print head's as well as service
Posted on Jan 13, 2010
komguy
  • 2306 Answers
SOURCE: i need to replace the printhead the printer keeps
The part number is QY6-0061-000, it will cost you around $60.00, I believe www.precisionroller.com has those in stock, but sometimes amazon will have them too.
Posted on Jan 14, 2010
SOURCE: Error: The type of Printhead is incorrect, Install the correct printhead.
Ok i know this is kinda old, but i found a solution.
First to those people to state I found a solution from hp, cannon etc etc and not give out the direct link, or instructions, then whats the point fing posting????
This error happens when you install an oem cartridge onto your system. Or havent used it in a while, so the machine is somehow misfigured.
This solution is for canon mp800, simply switch off printer. HOLD stop/reset and press and HOLD on/off button. release stop/reset. Now press stop.reset twice. then release on/off button, press stop/reset 4 times, wait 20 seconds, press on/off button twice.
switch machine back on and the printer should find the cartridges.
This method maybe the same for your mp*** if not google RESET CANON PRINTER MP*** and you'll find the correct buttons to press.
here's a printer on reseting a bunch of canon printers http://tricks-collections.com/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
good luck.. and FU canon for adding you scamming chips into cartridges.
Posted on Jun 11, 2010
Says the type of printhead is incorrect but has printed a few minutes ago fine and always has been ok. Help
Turn off your printer, take out print heads, first color then black and try
if you get always that "incorrect" message, uninstall it and reinstall it. If still same issue you have an electroinc failure of your printer and should take it to repair.
Jul 08, 2015 | Office Equipment & Supplies
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Jun 19, 2014 | Canon MX882 All-In-One InkJet Printer
Canon mx895,UO52 type of print head incorrect
try removing printhead, switching power off then switch on and re-install printhead.
Apr 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
The type of print head is incorrect install the correct prin head
EEPROM-Data in the printhead are faulty.
Replace the Printhead.
Part Number: QY6-0061
Feb 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP600 Printer Message comes up with: The type of print head is incorrect. Instal the conrrect print head!
Try removing the printhead and cleaning the contacts on the back with metho. Works sometimes...but not always. Moving the installed printhead slightly in the cradle it sits in, can also "spark" it back to life.
hope this helps
LC
www.inkbank.com.au
Nov 10, 2010 | Canon Office Equipment & Supplies
I need to replace the printhead the printer keeps coming up error the type of printhead is incorrect install the correct printhead
Jan 14, 2010 | Canon MP830 All-In-One Printer
The type of print head is incorrect. install correct print head
That happens when the printhead goes out, you'll need a new printhead,QY6-0075-000 around $50.00
Aug 11, 2009 | Canon MP610 Photo All-In-One Printer
Incorrect printhead
It just means that the printhead is defective, All of the Canon machines say that when the printhead goes out.
Jul 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My Canon PIXMA MP830 all-in-one is saying "the type of printhead is incorrect, install the correct printhead."
The cartrige is what holds the ink, the printhead is the device that puts the ink onto the paper.
So if your out of ink, then you need a new cartridge, if you have a new cartridge and you are having issues printing good quality, then you may need a new printhead.
you can get the ink here: http://printerinkcartridgesearch.printcountry.com/canon-pixma-mp830-ink-cartridges.htm
printhead is about 49.95
http://www.precisionroller.com/k_canon_pixma_mp830_print_head/m114d8577c104/
Hope this helps!
Brad Nelson
Mar 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP560 All-In-One InkJet Printer Logo
54 people viewed this question
old marine
old marine
