Question about Hyundai ImageQuest L70N 17" LCD Monitor
Need a manual
I need to know how to use the buttons on my monitor,didn't come with manual and I don't know how to adjust the contrast,or brightness,or even use the menu.The monitor works fine except for that .Does anyone know where to fine a manual or user guide for this monitor.Hyundai Imagequest L70N 17"
  • 34 Answers
I have downloaded the manual from Hyundai website en_man_monitor_lseries_l52s.zip
Posted on Jun 19, 2009
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
Want to adjust brightness and contrast on monitor
First you need to know the Make and Model of the Monitor. Second, go back to store where you bought the Monitor and aske for a Manual. Third, when you learn about the Make and Model of the Monitor, search Google for an Instruction Manual to it. Any of these suggestions would help you!
Oct 23, 2017 | ACER INCORPORATED eMachines eMachine...
I don't understand anything about changing the display settings on my Acer p215h monitor I push the buttons but can't figure out what to do
umm...usually if it is a desk top there will be buttons either on the side, front or back or even the top, one looks like a sun and another looks like a square thats normally half white and half black. they are your brightness and contrast...push either end of the buttons to adjust more bright or less bright, more contrast or less contrast.
Sep 16, 2012 | Acer P215H LCD Monitor
User mode window (for adjusting the contrast, brightness etc) appears again again automatically.
First off... I would Re-Start your computer...OR...Shut down manually... to see if this fixes your problem. It's possible your computer didn't accept the changed setting? But...what you are experiencing is a Corrupt File, which will need to be removed!
Not sure exactly what you did? Where you trying to adjust the contrast, brightness, etc,.?
If you went through your Desktop to adjust these settings, always make sure you select APPLY and OK..
If you went through your System to Change your Resloution, you may have a Conflict with your chipset or even Malfunctioned it?
If re-starting your computer didn't fix your problem, than shut your computer down again!
Upon,..Re-booting...This time hold the Control Key down, so you can get into SAFE MODE!
I would then do a SYSTEM RESTORE under (SAFE MODE) and Restore your computer back to an earlier period that your computer was working correctly! Even, if you cleared the problem on the first step provided! Just type in the search box in your Control Panel System Restore! Or you can type in at the START Button...System Restore!
Also, while in SAFE Mode...go to your Device Drivers in your Device Manager and check for any setting that have a yellow symbol next to them...Click on each one and Update the Drivers!
Always, make sure...you Re-Start your computer after doing any changes...!
If you need further assistance, please don't hesistate to reply back to me! I'll be happy to help you!
Kind Regards!
Martie
Sep 10, 2011 | Dell E773C 17" CRT Monitor
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
Need to adjust the contrast on my monitor.
You will not find contrast controls for most laptops. This is a funtion that you found on most desktop CRT monitors. However, xp and vista has some features on smoothing and such of your viewing icons in the basic right click on desktop/select properties
Sep 03, 2009 | Computers & Internet
Contrast and Brightness require adjustment
hi im josh in cebu phils. Maureen may i help you? If it happened yesterday that the contrast box keep on coming. there's a problem in your monitor.so try to check the buttons if covered with dust cleaning may solved the problem.Maureen if you have the manual use it in adjusting the resolution and if you dont have try to press the button mark + or increase just press both of the to the brightnest as posible so that you may be able to proceed another action. thats all for now.hope i helped you.good luck.
Feb 26, 2009 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
VA721/Windows 2000 - contrast/brightness settings grayed out
The monitor is probably set to sRGB under "color adjust".
Change it to 6500K, which is default, and you should be able to adjust brightness and contrast.
Jan 01, 2009 | ViewSonic VA721 17" LCD Monitor
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
Need help with Mitsubishi 15
Try pushing the contrast button, and then some of the other buttons once the contrast menu is up. To control those menus you use the buttons on the front of the monitor, not the keyboard and mouse.
Nov 24, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Hyundai ImageQuest L70N 17" LCD Monitor Logo
430 people viewed this question
Top Hyundai Computers & Internet Experts
Marvin
Marvin
rhodesworks
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
