Question about Veridian Healthcare 19-005 Veridian Pedometer
Reset time on a veridian 19-005
Reset time
My model 11-505 came without instructions I have acute bronchitis and I need this now. Veridian healthcare model 11-505 nebulizer
if there are instructions it will be in a pdf version
go google and type in ---user manual for veridian health care model 11-505 nebulizer --download and print out
Oct 08, 2016 | Health & Beauty
Change from Celsius to fareinhight
While it's on, tap both mem and mode button at the same time. Unless you have big thumb, you might want to use your left and right to do this.
Feb 22, 2015 | Veridian Healthcare 09-348 Infrared Ear...
Need instruction manual for Veridian Oxometer model 11-5-D
Try asking for the manual here: http://www.veridianhealthcare.com/contactform.html or call Veridian Healthcare's customer support line, 1-866-326-1313 , M-F, 8:30-4:30 CST.
I hope this helps.
Oct 04, 2014 | Sewing Machines
How do I change veridian 09-348 from celcius to Fahrenheit?
turn it on and then hold both the mode and mem button it should toggle after a second or so
Aug 28, 2014 | Veridian Healthcare 09-348 Infrared Ear...
How can I set the date and time on my Veridian Smartheart blood pressure cuff?
With the unit off, hold down the set key until the year shows up. Press the mem key to advance by 1, or press the set key to set/accept that value and/or advance to next setting. See: Omron Wrist Blood Pressure Monitor
Aug 26, 2014 | Veridian Healthcare Smartheart Arm Digital...
Veridian 01-515 Series
when cuff is off, press the M/+ button then press the user select button (the little person) to select user 1 or 2. Then press and hold the M/+ button until CL shows on screen. Press the user button again and screen will read CL 00. Repeat for other user if needed.
Jul 08, 2014 | Veridian Health & Beauty
How do I reset it for daily use?
Unfortunately this pedometer does not have a daily reset.
Oct 15, 2013 | Veridian Healthcare 19-005 Veridian...
Change function
on the hand held unit there are 2 switched to the right and left one changes from F to C and the other is a volume switch.
May 03, 2013 | Veridian Healthcare, LLC Veridian Mini...
How to change setting from celcisus to farenheit
hold the power button once its on until it beeps then push one of the other buttons to change
Veridian Healthcare 19-005 Veridian Pedometer Logo
Top Veridian Healthcare Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Veridian Healthcare Exercise and Fitnes Expert? Answer questions, earn points and help others
