Question about Minolta EP4000/5000 CS/PRO Copier
How to clear a code from a CS Pro EP3000 - Minolta EP4000/5000 CS/PRO Copier
  • Minolta Master
  • 6,674 Answers
WHAT CODE SIR/MAM?
Posted on Dec 29, 2014
2 Suggested Answers
firesnake09
  • 2923 Answers
SOURCE: ERROR CODE CO5OO FOR MINOLTA CS/PRO 2080 ????
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Thank you and good luck!
Posted on May 02, 2010
Ep3000 how to clear a code co200
Sir/Mam
Open close the front door. if it comes back the charge corona wire above the drum or the transfer & separation wires are the problem. The charge wire is above the drum have to remove the drum section to see it they are very thin gold plated wires that place a electrical charge on the drum prior to the image being placed on the drum.
The Transfer and separation wire are directly below the drum Transfer allows the image to be placed on the paper as it comes underneath the drum and above this very thin gold plated wire, The separation wire the second one prevents the paper from sticking to the drum. The xfer/sep assy. wires are located directly under the drum. then are very thin mite be broken. Grounding the High voltage. pull down and pull out the assy. to check it. There is cleaning handle try pushing it back and forth. If they are broke replace tem very carefully. Percission Roller may have them
If available
Apr 21, 2014 | Minolta EP4000/5000 CS/PRO Copier
On display showing problem code 500
Sir,
To clear this code requires you to gain access to the System reset. Open front door locate a small panel with one screw to release it in side will find two small black buttons find service and let machine reset if the code persists then your fusers is gone, the EP3000 is a legacy equipment may find a problem in locating spare parts if the thermistor, thermosat or fuser lamp is shot. Ensure machine is on when you attempt above.
Sep 06, 2012 | Minolta Office Equipment & Supplies
Why are my minolta EP3000 copies very dark all the time?
has the optics been cleaned all the mirrors below the big glass how about the drum and developer has it been replaced?
Jun 29, 2012 | Minolta EP1083 CS/PRO Copier
Error co500 cspro ep3000
open front door to your left a small access cover remove the screw press the trouble reset button. if the code comes back have a konicaminolta tech look at it, continue reset may start a fire you are resetting code for the fuser the hot part of the copier
Oct 13, 2011 | Minolta EP4000/5000 CS/PRO Copier
My minolta EP3000 CSPRO shows error code coooo
Main motor remove the fuser unit the hot part check for broken gears also look in the back where the fuser go for bad gear, then check the drum assy. for old cleaning blade if yellow replace it or the drum is stuck use thumbs on the edge of the drum to turn it clockwise looking at the front counter clockwise messes with the cleaning blade. Worse case the motor is dead and or the control board, you try the below web site try for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 25, 2011 | Minolta EP1031/1031F CS/PRO Copier
Minolta cs pro EP3000 copier. The copy is too dark even on lightest.thanks
Clean the optical parts:mirrors,lens and the charge and transfer/sepaRATOR CORONAS.
May 13, 2010 | Office Equipment & Supplies
EP3000 error code c0500 will not clear
Sir,
Feb 02, 2010 | Konica Minolta DiALTA Di200 Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
49 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
