Question about Troy Garden
I can start my mower by turning the key swigch to the first click and connecting the positive battery cable straight to the starter
SOURCE: Starter fails to start.
I'm having the same problem. The dealership keeps telling me it's the starter. I've replaced starter and still have the same problem. I have had all the wiring and new key swith put in and still have the same problem. I guess were in the same boat!!!
Posted on Jul 09, 2008
SOURCE: Ignition turns but no start
it is an issue in the steering column. I am getting my 2005 back today, finally. 2 mechanics and they said they have never seen this issue before!!
The steering wheel has to be pulled off and the part replaced. It is cutting all power to the ignition switch. It is not the starter or the Alternator... it is in the steering column. It should be about 200.00 to fix.
Deb
Posted on Mar 03, 2009
  • 599 Answers
SOURCE: 1985 Toyota pickup (22R) won't start just hear a
turn on the head lights and while someone watches the head lights try to start the car, do the headlights dim or go off get back to me and we'll go from there
Posted on Apr 24, 2009
  • 106 Answers
SOURCE: My riding mower blows fuses once you turn the key.
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
Posted on Jun 04, 2009
  • 376 Answers
SOURCE: Murray riding mower won't start
Sounds like a defective starter solenoid.
Posted on Jun 18, 2009
My mower wont start. Husqvarna rz5424
If your starter solenoid is separate from the starter, then the following is to check the starter solenoid - (test bypasses solenoid)
1) take a battery jumper cable and connect one end to the positive post of the battery.
2) Turn the key to the ON position.
3) Then take the other end of the jumper cable used in step 1 and touch it to the connection on the starter (bolt) that has the cable coming from the starter solenoid You will see sparks when you touch this.
This should cause the starter and engine to crank over. If nothing happens, then it could be the starter is bad.
Starter test -
1) Try removing the starter from the engine.
2) Connect a jumper cable to the negative battery post and the other end to the starter housing, to make a good ground circuit.
3) connect a jumper cable to the positive side of the battery and then touch the bolt/post that usually connects to the starter solenoid.
The starter gear should spin when you touch this connection. If not , it's faulty.
Dec 26, 2015 | Husqvarna Garden
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Riding mower won't start & makes clicking sound when I turn key over
MAKE SURE BATTERY IS CHARGED IF IS THEN JUMP LAWN MOWER AT STARTER IF STARTS BAD BATTERY ARE STARTER RELAY COST 60.00 I STILL THINK YOUR BATTERY IS BAD OR DEAD NOT ENOUGH CHARGE IN IT
Sep 01, 2014 | Garden
I have 2000 john deere 420 and it wont turn over
The starting circuit is dependent upon the clutch safety ans PTO being off. Here are some steps to take:
1. Ensure battery is fully charged
2. Turn key on and turn PTO on then back off. Listen for clunk
3. Press clutch in fully and turn key to start position. If still no sound at all, hold key in start position and move clutch foot up and down, listening for solenoid click. If click but no crank, starter or solenoid or battery cable connection is bad. Start by wiggling cables, looking for any looseness. Next check solenoid and cables. If that doesn't fix it, starter or solenoid may be bad. There may be a fuse in the circuit. Check them out also.
if it cranks but doesn't start, you have a fuel or ignition problem. Good luck. Let us know what you find
Jun 22, 2014 | John Deere 420,1020,2010,2020,2510,2520...
My 155c John Deere will not start! Brand new charged battery....I turn the key...nothing(no clicking either). When bypassing it to cellinoid, it starts right up. When I shut off the mower, I have to...
Usually when the key is turned to start position the starter soleniod engages thus applying power to the starter. There are three possible causes to your problem . (1) Check for 12vdc at the terminal on the soleniod when the key is turned to start position, if there is 12vdc at the terminal then the key switch is good. (2) loose or bad cable connection at the soleniod, check connections. (3) bad soleniod -- replace it. generally you will hear a click from the soleniod when the key is turned to start position. Also be sure to check that ALL safety switches are engaged. You may need someone to sit in the drivers seat so that switch will be "made" / engaged. Park Brake is set, mowing blades are "NOT " being engaged, on some mowers if the transmission is in reverse ,even tho the brake is set the mower will not start.
Nov 10, 2013 | Garden
I have a question. If yor mower want turn over all you hear when you turn the key is the volt meter click. There is fire from battery to solenoid but on the other side of solenoid going to the starter no...
Hello Lynn,
Sounds like you have a problem on the key controlled side, so:
1. Power from the battery to the key switch? 6V or 12V I would guess.
2. With the key in the "Start" position, have you got voltage to the thin wire/small terminal on the solenoid?
3. Do you have a good ground from the starter motor to the chassis?
If all the above checks out then the control circuit for the starter should all be working A-OK & when you turn the key to the "Start" position you should be getting a good, strong "Click" from the solenoid.
So - on the starter circuit:
1. The HD cable feeding the solenoid should always have battery voltage on it?
2. When you operate the key you should hear the solenoid "Click" and the voltage from the HD feed cable should now be connected to the other HD terminal on the solenoid (these are the two you are shorting out with your screw driver to get the motor to turn the engine over).
3. If the solenoid is "Clicking" when you operate the key & the voltage from the main supply cable is being passed to the second HD terminal, but the motor is not operating, then you need to check your ground cable.
Hopefully by now you will have found & fixed the problem :)
Sep 07, 2013 | Cars & Trucks
Engine cut out when it was turning over and now when i try starting it i have nothing when i turn the key i put jump leads on the battery from my car but still nothing
Paul:
I would disconnect the positive lead terminal from the battery on the mower, then follow the positive lead to the starter solenoid. Check the connection there for security (is it clean and tight?). Then the connections on the starter... disconnect, clean and tighten them. remove the terminal from the negative battery pole, and remove the ground cable from the frame of the machine, clean the terminal and the point where the negative cable contacts the frame of the machine... do the same for each battery terminal and cable terminal. Connect the negative battery terminal last. Your problems should be solved.
Sep 02, 2012 | Northstar Garden
Won't turn over when I try to start
Really clean your battery connectors, Make sure jumper cables are beefy or they will not allow enough power. If your starter clicks, it is either stuck engine, weak battery, dead solenoid connectors or dead armature inside the starter. In rare cases cable connections can come loose at the solenoid (A mechanic knows to take some solenoids apart and turn the connectors upside down to the uncorroded side.) Make sure your blade is not stuck, make sure your brake is in the correct position, make sure your engage levers and shift linkage are in the neutral start positions.
May 17, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My mower wont start...i replaced the battery and it just clicks
Have a friend jump start the mower while you a seated on it. Turn the key to the "on" position. Connect the black jumper cable from a known good battery to a good ground on the mower and the red cable directly to the electrical connection of the starter. If the starter does not engage, it is faulty.
Apr 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
12 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
