Question about John Deere Garden
What point wires goes to hot and the ground on a john deere lawn tractor 214 kohler engine
Had to rewire it and the diagram I found online does not show which wires goes to hot or the ground. Any help, much appreciated.
    Champion:
  • 279 Answers
The HOT wire goes to the contacts and the ground normally goes at the mounting screw
Posted on Jun 03, 2014
SOURCE: illustrated parts list for john deere 102 riding lawnmower
Go online to www.johndeere.com click on residenial tractors,then click on services and support. You should be able to get an answer there. Otherwise contact them through email.
Posted on Apr 08, 2009
  • 218 Answers
SOURCE: I NEED TO SEE A DIAGRAM ON A JOHN DEERE 214 LAWN
Hi..my name is Keith..and you can go to an online lawn mower parts site and put in your model of lawn mower and search for the mowing deck..and they will have a diagram of the mowing deck with the belt on it..and there are several sites online but i'll give you the one i use www.outdoordistributers.com ...i hope this has helped
Posted on Jul 12, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
wireguy212
  • 1627 Answers
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Posted on Nov 10, 2009
wireguy212
  • 1627 Answers
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Posted on Apr 18, 2010
What size belt goes on john deere 214 deck
Go to Google type in John Deere lawn tractor model number then owners manual
Jul 08, 2017 | John Deere Garden
John Deere 214 with Kohler K321
Check carby is not to rich,"mixture screw" check for fuel blockage on fuel tap.
Sep 27, 2016 | John Deere Garden
Wiring diagram for a john deere sst18 lawn tractor
Russell if you truly want to figure out this problem you need to look at the wires and ware they connect .And what they connect to then drew your own wiring diagram its not that difficult if you break down and do a few tests with an OHM meter to see what is connected and what happens when you through a switch or run a jumper wire to a ground .
If you think about its not really that complex .
Jun 08, 2016 | John Starter Deere Sst18 Spin Steer Deere...
I have JD 214 that I've replace coil, points spark plug,wire yet still getting no spark the mower just quit run inspection I found that the points was burnt and plastic where power attached was melted
Wow, a tractor with points. That's rare these days. I believe your tractor was made between 1975 and 1987. It's a 200 series. Does it have the 14 hp Kohler?
Not sure about your problem. On a modern day tractor with electronic ignition, I would check the safety switch system. In your case, I would check the fuse, key switch, and look at the kill wire running off the coils to see if there is worn insulation. If you have seat safety or PTO switches check them too.
You can get parts here:
John Deere 214 Lawn and Garden Tractor Parts
Apr 16, 2015 | Garden
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
Apr 21, 2014 | John Deere Garden
John deere wiring
It maybe charging lead. Goes to key switch.
Mar 11, 2014 | Garden
1976 JD 214 lawn mower Kohler engine K321AQS Model. Runs rough after 30 - 40 minutes use and starts to shake and over heats. rebuilt engine, honed cyclinder second time. New coil. New spark plug wire....
When it shuts down crack the fuel cap and listen for the woosh of a vacuum on the fuel tank. If you hear this, clean the pinhole vent in the fuel cap, or replace it. Being partially plugged would cause you to be starved for fuel and could explain your issue, and why it goes away after a period of time.
Regards, --W/D--
Jul 19, 2009 | John Deere &Reg Branded 27" Tractor Metal...
Garden Logo
130 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
