Question about Recoton Advent Advent AS2 Main / Stereo Speaker
Need speaker covers and frames
Speaker covers were broken by 3 year old, need replacements
I have a Bugaboo frog. I accidentally broke the piece that attaches the canopy to the frame, on one side. What do I do now?
if it's within 2 years old it's covered.
Call toll free: image_gallery?uuid=6a479f2d-8718-40f4-b775-292deedb9bd4&groupid=10136&t=1318502576820 800.460.2922
Email : serviceus@bugaboo.com
Fax: 310.496.0988
Hours: Mon-Fri: 10am-7pm EST
http://www.bugaboo.com/all-products
Sep 06, 2012 | Bugaboo Frog - Blue Stroller
How do I remove the door speaker cover in a rexton to get access to the speaker
Hi, I don't believe that you can gain access to the speakers from the outside, the covers are not removable, they are an integral part of the door trim. You'll need to lift the small round upholstery caps, undo all the screws that hold the arms rest in place and pop-off the panel fasteners to lift the entire trim off the door. Before you can separate the trim, you'll have to also disconnect the wiring sockets and door lock linkages. Only after you lift the trim off you will see the speakers which are screwed onto the interior of the door frame itself. You will also need to lift the plastic dust cover glued to the door frame. Carefull, that black stuff is very sticky and a bit messy to handle.
From memory, they are about 110mm cone speakers and the rubber suspension ring has a tendency to perish after about 8 - 10 years, so I replaced mine with some aftermarket, 200W, 3 way speakers.
But beware, it's not quite that simple. The plastic mounts for the speakers make it hard to insert just any replacement speaker. The mount is actually part of the speaker body and I had to cut mine out with a hacksaw. I also had to do some modifications to the remainder of the mount to attach the replacement speakers. I didn't have any choice as the original speakers had collapsed and rattled like crazy, but the result was worth it. Good luck.
Jun 08, 2012 | SsangYong Rexton Cars & Trucks
I have bvlgari sunglasses code 8003-B 825/73 and the hingehas broken I have unscrewed the hinge and need a new hinge where can i get one please
Hi Pump_house
How old are the glasses? Bvlgari has a 2 year warranty that covers defects on the frame. You can send them back to the manufacturer if you are still within that 2 year period.
May 11, 2011 | Bvlgari BV 8008 Sunglasses
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
Mar 18, 2011 | Brother HL 5250DN Laser Printer
Speakers sound fuzzy , broken
a cover is on the dor panels remove it first and unscrew it
Jul 11, 2009 | Car Audio & Video
Fridgidaire dyrer three years old
the heater has most likley shorted to yhe frame and needs to be replaced
Dec 23, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Broken screen
Most rear projection screen are only secured with a few screws along the bottom side of the screen frame behind the speaker grille . so you have to remove the speaker grille cover then remove the screen frame screws then just slide the frame assembly up to disengage the upper clips.If you dont see any screws through the rear cabinet into the frame this is how your screen frame should come off
Jun 29, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Battery cover broken
If that new try the Polaroid Website technical Support team. But commercial repair shops are a no-no- will it contact OK if you tape it?
Jun 13, 2007 | Polaroid i832 Digital Camera
Recoton Advent Advent AS2 Main / Stereo Speaker Logo
32 people viewed this question
Top Recoton Advent Audio Players & Recorders Experts
Ron Rak
Ron Rak
Level 1 Expert
NOEL
NOEL
Tom Chichester
Are you a Recoton Advent Audio Player and Recorder Expert? Answer questions, earn points and help others
