Question about Kenmore 300 Series Water Softener
Craftsman wheeled Weedtrimmer Model 917.773741 will not start. primer bulb not getting gas in
Schematic of carburator on Model No. 917.776740 Briggs and Stratton engine on a 675 Series on a Craftsman Wheeled Weedtrimmer.
remove the water from the fuel tank
\ put in about 2 table spoons of methylated spirits in to fresh fuel in the tank , use a primer bulb and pull several times to get the new fuel into the carby
The methylated spirits breaks the water down so that it goes through the jet
Jun 11, 2016 | Craftsman Garden
Craftsman tiller won't start unless I manually prime cylinder with gas. There is no primer bulb. Can I retrofit a primer bulb in the gas line?
Hi
You can insert a primer system into your fuel system
Just follow the fuel flow below
Please take time to rate me
Bud
Oct 23, 2012 | Craftsman Garden
I have a Craftsman Weedwacker 25cc 358.791030 that won't start. Primer bulb is not getting gas. Gas line is connected to the filter resting at the bottom of the gas tank. The line for the primer bulb...
that line should be longer, it contains the filter which is the pick up, and should rest inside the tank fully,, see if its possible to pull that line farther into the tank, its not going to start until the primer bulb fills
Jul 24, 2011 | Craftsman Convertible 25cc. Gas Line...
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Primer bulb doesn't pump gas
Does the primer bulb pop back out or does it come out slowly? Is the inline hose in good shape or has a crack where it can **** air in? Did you check to see if the diaphgram in the carb is pliable or is it paper-like and needs replaced. Or your carb could be stopped up.
Only one problem..I can't think of any weedtrimmer that has an inline fuel filter. They are usually located in the gas tank.
Jun 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Kenmore 300 Series Water Softener Logo
80 people viewed this question
Top Kenmore Water Dispensing & Filtration Experts
Bill Boyd
john h
Dennis
Are you a Kenmore Water Dispensing and Filtration Expert? Answer questions, earn points and help others
