Question about Frigidaire ATF6000ES Front Load Washer
Model gltr1167oaso\ door hinge seems bent
Model gltr1167oaso
Door hinge seems bent because door does't close tight on bottom and water comes out???
    President:
  • 1,185 Answers
Are you sure someone has not used their knee to push the machine back into positon and have distorted the front panel.
Worth putting a straight edge across the front of the machine where the lower bit of the door gasket stops to see if there is a dip there
Posted on Jun 20, 2009
How do I remove the door of Chevrolet spark
This is a TWO person job!
-Open the window all the way. This will give you something to use as a handle.
-Open the door and disconnect the wiring loom connector.
-Unbolt the door check strap bar between the hinges.
-Support the weight of the door and locate the hinge bolt on the door.
-Loosen, but do not remove, on both hinges.
-Get your helper to support the door as it might drop suddenly.
-Remove the BOTTOM hinge bolts first. Then remove the UPPER hinge bolts.
-The door should drop out of position.
REINSTALLING.
-Support the door in the open position.
-Fit the top bolt in the top hinge until finger tight.
-Repeat this for the bottom hinge. It will take some of the weight of the door.
-Refit the lower bolts for both hinges until finger tight.
-GENTLY swing the door closed to check it is not positioned badly.
-Reopen the door and tighten the hinge bolts as follows.
Top hinge, top bolt.
Bottom hinge, top bolt.
Top hinge, bottom bolt.
Bottom hinge, bottom bolt.
-Tighten until tight BUT do NOT overtighten.
-Refit the door check strap.
-Reconnect the wiring loom connector.
-Close the door to check fit.
Jan 23, 2018 | Chevrolet Cars & Trucks
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
Refrigiderator door sagging not closing properly
Please give us something to start with.
What is the make and model of your freezer?
Have you checked the hinge is securely fastened?
Has someone leaned on the door and bent a hinge?
Nov 20, 2013 | Refrigerators
Oven door won't quite close tightly. I can push it about another 1/4 inch to close it completely.
You need to replace the hinges in the door. Go online to a spares website and enter make and model and order new hinges. You can replace them by unhooking the door, just takes a little effort, you might need to flick back latch on hinge and lift out. Remove inner door panel, usually 4 screws and remove. then change hinges. The 2 big pieces are the hinges.
  • images?q=tbn:and9gcsg1plmaxnucdapg-xpimmjauz_p4kgblmyf6iotcmgyh-hv4v3
Mar 09, 2011 | Ovens
Door leaks water
funny on these washers they used a piano hinge for the upper and lower hinge often they get bent real easliy and sometimes you have to replace the front panel
Jun 02, 2010 | General Electric WSSH300G Front Load...
My 1997 Jeep Grand Cheroke's doors close funny. Both of them don't close smoothly. Anyone else have this problem? It's not when the door latches it's during the close, like something is bent but it's on...
Each door has two hinges. The bottom hinge has a lever spring and two rollers attached that prevents the door from swinging freely when it is opened or closed. (one roller for opening and one for closing) If the door seems like its bent, it is probably because the rollers are frozen and when you open/close the door the lever spring is scraping across the raised edges of the rollers instead of riding them. If the door is not moving smoothly, or is making loud creaking noises, give a good dose of WD-40 to the hinges as well as the rollers, especially the rollers. The rollers should roll when the lever spring engages it as you open/close the door.
Dec 20, 2009 | 1997 Jeep Grand Cherokee
Our fridge door won't close properly
The door hinges have nylon bushings/washers to help them work smoothly. If the unit is very old and had a lot of use (like a large family) the bushings or washers could be just worn away. This also is indicated if the doors seem to be misaligned. If the doors don't seem out of place, it could just be that the unit is not sitting on a level surface, causing the box to twist and the doors th therefore bind.
Other possibilities: The door is burdened heavily with the milk, juices, food, etc. and therefore is just plain heavy. You have a "water-thru-the-door" unit and some leak has occurred to fill the door and it's insulation with water. (eww!)
Check to see that the surface is level, and that the door fits correctly. Make replacements or adjustments as necessary. Lighten the load on the door, or fix the leak.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 18, 2008 | Kenmore Refrigerators
Door very stiff won't close tight
I have the same problem with the side doors of my 04 express. I put penetrating oil on the hinge pin with a hypodermic needle (hard to find). It is important that the oil gets into the hinge. I bent one set of hinges and broke a hinge because I waited too long to oil the hinge. The door may not close correctly because the hinge may be slightly bent. Keep all other hinges well lubed especially during the winter months when the hinges can be exposed to road salt. Fixing a bent hinge is difficult at best.
Aug 28, 2008 | 2004 Chevrolet Express
Freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
Oven door will not seal at top.
The same thing with mine. I took apart the door today and found the hinges a little bent. I think it should be ok to bent them the opposite way a little with some mole grips......and then I must remember not to move the stove out for cleaning by the oven door handle again (oops).
Door comes off (unlock hinges and lift up). undo 4 screws on the bottom edge and then two on the inside of the door handle then it comes apart - beware as it's heavy. The hinges themselves come off with two screw each.
Jan 27, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire ATF6000ES Front Load Washer Logo
113 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
