Question about John Deere Garden
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
  • 28 Answers
If that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
Posted on Jun 20, 2014
wadembly
  • 489 Answers
SOURCE: No spark
did you make sure the gap was set right on coil & flywheel it should be .020 between magnet on flywheel & the coil & the same thing with the points in the open possition between points & condensor
Posted on Jun 08, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
nova2nv
  • 197 Answers
SOURCE: I have a John Deere LT 1`33 lawn tractor with a 13
I believe they are 8mmX35mm.
Posted on Nov 14, 2009
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Posted on Jan 08, 2010
wireguy212
  • 1627 Answers
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Posted on Apr 18, 2010
What size belt goes on john deere 214 deck
Go to Google type in John Deere lawn tractor model number then owners manual
Jul 08, 2017 | John Deere Garden
John Deere 214 with Kohler K321
Check carby is not to rich,"mixture screw" check for fuel blockage on fuel tap.
Sep 27, 2016 | John Deere Garden
I have JD 214 that I've replace coil, points spark plug,wire yet still getting no spark the mower just quit run inspection I found that the points was burnt and plastic where power attached was melted
Wow, a tractor with points. That's rare these days. I believe your tractor was made between 1975 and 1987. It's a 200 series. Does it have the 14 hp Kohler?
Not sure about your problem. On a modern day tractor with electronic ignition, I would check the safety switch system. In your case, I would check the fuse, key switch, and look at the kill wire running off the coils to see if there is worn insulation. If you have seat safety or PTO switches check them too.
You can get parts here:
John Deere 214 Lawn and Garden Tractor Parts
Apr 16, 2015 | Garden
What point wires goes to hot and the ground on a john deere lawn tractor 214 kohler engine
The HOT wire goes to the contacts and the ground normally goes at the mounting screw
Apr 21, 2014 | John Deere Garden
No spark to the plug Kohler 8hp lawnmower engine
Check ingition switch, check battery voltage 12-12 1/2 volts,check in run position same voltage, check in start position same voltage
We've check switch first. If not problem we've check the points for proper voltage and opening and closing.
Jan 17, 2012 | John Deere Garden
1976 JD 214 lawn mower Kohler engine K321AQS Model. Runs rough after 30 - 40 minutes use and starts to shake and over heats. rebuilt engine, honed cyclinder second time. New coil. New spark plug wire....
When it shuts down crack the fuel cap and listen for the woosh of a vacuum on the fuel tank. If you hear this, clean the pinhole vent in the fuel cap, or replace it. Being partially plugged would cause you to be starved for fuel and could explain your issue, and why it goes away after a period of time.
Regards, --W/D--
Jul 19, 2009 | John Deere &Reg Branded 27" Tractor Metal...
Garden Logo
215 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
