Question about Cobra Fi2000 PowrPro Tuner
Rear Cyl. running lean
On my 2013 Victory Cross Country Tour I am getting a fault code indicating that the rear cylinder is running too lean. The processor light is on and solid. What steps can I take to diagnose and correct this proble?
My cruise control on my 2011 Cross Country quit working. The red light comes on when you hit pwr switch but when you the set switch the light on the front panel just blink, it won't stay on.
Hi, William cruise control systems are complicated any type of failure should be diagnosed and repaired by a certified technician that being said here is a list of troublemakers and the usual suspects are:
1. Faulty front or rear brake light switches.
2. Faulty TPS sensor.
3. Faulty clutch safety switch.
4. Faulty cruise control on/off switch.
5. Faulty engine on/off switch.
6. Faulty set/resume switch.
7. Speed drops below 30mph.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Cruise Control not working
Lash Learn Procedure for XC Cruise Control
2011 POLARIS VICTORY CROSS ROADS VICTORY CROSS COUNTRY MOTORCYCLE SERVICE...
Motorcycle Service Parts Part Finder Victory Motorcycles Store
http://cdn.polarisindustries.com/polaris/common/parts-manuals/9923026r01.pdf
Feb 14, 2017 | 2011 Victory Cross Country
Where's the fuses located on the victory classic cruiser
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Victory despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
victory classic cruiser fuse panel location Google Search
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=17809
Victory Motorcycles Vision Tour 2013 Owner Manual Fuse Replacement Fuse...
2010 Victory Vision Tour Service Manual pdf
Apr 19, 2016 | Victory Motorcycles
Cylinder 1 misfire detectedrich or lean air/fuel mixture fuel injecter fault and faulty crank shaft sensor
Wow... Thats a lot of diagnostic codes. First... The cyl #1 misfire will cause the Engine to run rich giving you a rich running engine. Therefore the rich lean code. This misfire on cyl #1 can also throw a crankshaft sensor code as it will slow down engine rpm. I would change the spark plug and ignition coil to cyl#1 and have the codes erased and see if that solves the problem. If not, you then need to persue any codes that may reappear.
Jun 06, 2015 | 1999 Kia Sephia
Why is it over charging
The regulator rectifier must be faulty it's the only component that has the job of stopping the battery from being over charged,usually the battery will get hot and dry up if it's over charging
Mar 15, 2015 | 2013 Victory Cross Country Tour
Console/radio display is blank but radio still works
Do you mean it is difficult to see or that it just doesn't work?
Mar 11, 2014 | Victory Motorcycles
How do i get rid of the tick from the motor. plugs changed spring 2013, run cleaners and additives nothing seems to be working, should I be concerned? second the front cylinders coughs at idle?
Engine ticks on a regular beat in tune with the rpm of the engine indicates a loose / burnt manifold gasket on a particular cylinder or a cracked manifold near a particular cylinder. It could also be a loose/ blown head gasket at the cylinder that is coughing at idle.
Jul 26, 2013 | 2007 Victory Vegas Jackpot
I have a 2011 victory cross country and want to hook up a trailer hitch what color wires do I tie into for the brakes, running lights and turn signals
Before you cut into the harness, look under the seat in front of the rear fender for a 4 flat trailer connector. I had a Victory in my shop last winter w/ a trailer hitch, and it looked to me like it was part of the factory harness. You'll need to build a whip long enough to get to the trailer-this one was wired through and stored in the left bag. If it's not there, contact me back and I'll look up the wire diagram for you. Good luck!
Jun 14, 2011 | Victory SM510R Motorcycles
08 Victory vision tour I have a squek while driving at low rpm that coensides with the tourqe of the engine. Drive belt looks good. could this be a bearing?
In general, if the rear wheel alignment isn't just about perfect, the drive belt will squeal. The colder the weather, the more noticeable the squeal will be. With proper allignment, when the rear wheel is off the ground, if you rotate the wheel in the forward direction, the belt should slowly move from the outside edge of the rear drive sprocket to the inside edge. When you rotate the wheel in the reverse direction, the belt should slowly move from the inside edge toward the outside edge.
Oct 17, 2009 | 2008 Victory Vision Street Tour
Cobra Fi2000 PowrPro Tuner Logo
Top Cobra Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Cobra Heating and Cooling Expert? Answer questions, earn points and help others
