Question about American Exchange AT&T CL84202 2 handset corded/cordless answering system with caller
Display light when phone idle
Display panel (on corded phone) lights up randomly when phone is idle. Particularly disturbing to see the room lit up in the middle of the night! But happens in daytime also. Sometimes flashes on and off repeatedly and displays "Ended" as though there had been a call that ended. The model #'s on our literature are: CL84100/CL84200/CL84250/CL84300 DECT 6.0 IT IS A CORDED, PLUS 2 CORDLESS SET.
Why is the display screen on my phone so faint?
the back light has failed. take it to a phone repairer or buy a new one.
Nov 09, 2014 | BT DECOR 2500 CORDED ANALOGUE TELEPHONE
Take the phone off do not disturb
Try pressing the FWD/DND button and look at the display. It might have 3 steps, FWD, DND, and FWD/DND Off. When you reach the Off part, the light will go away.
Carl
Sep 23, 2010 | Panasonic KX-T7630 Corded Phone
Even once I've listened to and deleted my voice mails, the red light will not go off. Any suggestions?
press the MESSAGE button and look at the display. It can be lit from any other station, and in fact, will be lit if someone dials your extension and presses MESSAGE or dials a "4".
The display tells you where the message came from and one of the soft keys will let you delete it.
Carl
Sep 07, 2010 | Panasonic KX-T7633 Corded Phone
Light wont turn off
Of course it will. Which one are you trying to turn off? Probably the ried one on top. Press MESSAGE and look at the display. It will tell you why it's lit, and one of the buttons will be CLEAR.
When you clear them all, the light goes out. Since the 7630 has no backlit display, it can't be that one. If it's an extension that is not equipped, you'll press PROGRAM the lit button, and CLEAR or (IIRC) TRANSFER and STORE.
How's that work for you?
Carl
Aug 26, 2010 | Panasonic KX-T7630 Corded Phone
The red light indicator will not shut off
Press the MESSAGES button and look at the display. The light can be lit from another source. One of the soft keys under the display will let you CLEAR the message.
Carl
Dec 23, 2009 | Panasonic KX-T7630 Corded Phone
Panasonic KXT7630 MESSAGE RINGER LAMP
It's not permanent, you just have to know how to turn it off :-)
When the phone is idle, the light is lit red and a 7636 will
say Message Waiting. At each phone, do not pick up the handset, but press MESSAGE. Your display will have who left the message on the top line and .EXIT CLEAR under soft keys 2 and 3.
Guess what :-) Press CLEAR and the message is erased. When the queue is empty, the light will go out.
Carl
Mar 16, 2009 | Panasonic KX-T7630 Corded Phone
Partner 18 light on extension stays on
Also make sure station DND (Do not disturb)is not on.
Feb 23, 2009 | Lucent PARTNER18 Corded Phone
Why is the mic "lit" on my NEC Elite 8-Button Display Telephone DTU-8D
when the light is lit it allows hansdfree use of your phone.
Jan 31, 2009 | NEC DTU 8D-2 Corded Phone
Comdial Executech
Press ITCM # 1 to turn off Speaker button light
Jan 15, 2008 | Comdial 6600 LCD Display Phone...
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
American Exchange AT&T CL84202 2 handset corded/cordless answering system with caller Logo
Top American Exchange Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an American Exchange Lands Phone Expert? Answer questions, earn points and help others
