Question about Sunbeam Simple Press 3030 Iron
SUNBEAM 3030 IRON LEAKS WATER - Sunbeam Simple Press 3030 Iron
4 Suggested Answers
SOURCE: sunbeam iron 4214
My iron leaks when I fill it past the fill line, so make sure you're filling it only to the fill line.
Posted on Dec 28, 2008
SOURCE: 4214 sunbeam iron
if the the iron is still in valid warranty time,ask the seller to change a new one or repair it for you i think! Or you can change a vertical type iron to instead !And it won`t leak,iron effect is better than the traditional iron ! 210c97a.jpg
Posted on Feb 14, 2009
SOURCE: water spray not working
I got a thin needle and gently made a hole through the centre of the nozzle - where the water would usually come out. That cleaned the scum build up out of it and it's working fine again. My nozzle does seem to look like its going into the iron but perhaps it's to get the correct angle of spray onto the clothes.
Posted on Mar 15, 2010
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
How to flush brown fluid water from Sunbeam Steam Master
Run a tank of 50/50 water and white vinegar through the steam cycly. Run two or three more tanks of plain water. This should clean it out safely.
Mar 13, 2013 | Sunbeam 4214 Iron
I have a turbosteam 6060 sunbeam iron. It will not steam, just beeps and cycles off
If I was you I would either go to the Sunbeam site and in the search box enter the model name and number and get a download a manual for fixing the iron or troubleshooting problems. If that don't work Send the Iron back to the company for a new one.
Feb 11, 2011 | Sunbeam 3017 Iron with Auto Shutoff
Good day I have an euro pro iron and it leaks all the time leaving water on washed clothes.also it leaks out of the bottom??
The water may come out at the bottom instead of steam. this is due to insufficient heat produced. So switch on your ironbox and keep it in full temperature using the knob. then the water will be coming out as steam and not as water itself. Try again.
I hope this is useful to you
Thanks
Jun 27, 2010 | Sunbeam Euro Press 4045 Iron
Iron was leaking and now stopped working - 2 months old
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Apr 01, 2010 | Sunbeam 4214 Iron
Water spray not working
Feb 13, 2010 | Sunbeam Irons
Iron leaks from place where you add water
it is cracked you should get a new one
Dec 11, 2009 | Sunbeam 4211 Iron
Water leaks from bottom of iron
heatman101
Jun 18, 2009 | Sunbeam Steam Master 4055 Iron
4214 sunbeam iron
Feb 14, 2009 | Sunbeam 4214 Iron
Sunbeam iron 4214
Nov 06, 2008 | Sunbeam 4214 Iron
Sunbeam Simple Press 3030 Iron Logo
29 people viewed this question
Top Sunbeam Irons Experts
Henry  Thomas
Henry Thomas
Tony
Karl H
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
