Question about Shark Helmet NV22L Shark Navigator Upright Bagless Vacuum
Shark navigator filter change - Shark Helmet NV22L Shark Navigator Upright Bagless Vacuum
Shark Navigator is making a loud noise when I turn it on.
Hello, this is Ava with Think Crucial.
To fix any noise issues that your Shark vacuum gives, a proper maintenance will do the trick. Most of the time ,cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. This video tutorial will guide you on how to do proper maintenance for your Shark cleaner:
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+navigator
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 02, 2016 | Shark Vacuums
Shark navigator lift away blowing hot air out of the filter
You would need to clean the tubes and every hose from any clogged particles or blockage and it will fix the problem. You can also check this video tutorial on how you can fix the issue by clicking the video link below:
http://www.thinkcrucial.com/search?type=product&q=shark
Ava B.
Oct 08, 2016 | Shark Nv352 Navigator Lift-away Complete...
Shark navigator nv 352 blowing hot air out of the filter
Ava B.
Filter ordered is too small and splits after two uses. What size to order?
Shark Professional Pet Navigator Lift Away Bagless Vacuum
Does it need a the filter since it is Bagless Vacuum??
Dec 06, 2015 | Shark Professional Pet Navigator Lift Away...
My Shark vacuum is making a weird noise how to fix it
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator Lift-Away Vacuum is making a loud noise while it's on then there's definitely a clog somewhere. Here' s a few places you should check prior to plugging in the vacuum and turning it on.
The first place to check would be the brush roll and belt. If you notice visible debris, like strands of hairs, or long carpet fibers this could be catching on the brush roll and causing it not to turn fully. Be sure to clear this debris from the brush roll and manually spin the brush roll a few times after you do so to help unearth and any other clogs. This may be the reason for the noise and its crucial that this part of your vacuum is clog free.
Another part of your vacuum to check would be your hose. Detach the hose and stretch it out as much as you can to see if any debris or clumps of dust are stuck inside. Using a broom handle can help if you see a clog, but it won't come out after you've stretched out the hose.
Another big factor would be a dirty filter in your vacuum. Most manufacturers recommend you change your filter on average every 3-6 months. However, it is recommended to change your filter even earlier depending on usage and allergy care. The cleaner your filters the less debris will get stuck in your vacuum, causing less clogs and overall less odd noises while vacuuming.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=nv355
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Nov 23, 2014 | Shark Navigator Lift-Away Professional...
Why cant i keep my hepa filter and cover on my new navigator?? help?
Are you sure that you are correctly connecting the filter, and flipping the tabs to "lock" it into the "closed" position.
Jun 13, 2014 | Shark Navigator Bagless Upright Vacuum
Why does navigator freestyle shark vacuum light blink even after charged?
I have had 2 Shark Cordless Freestyle vacuums. The first one, when it was fully charged, the blue light would glow softly. The newest one has a flashing blue light that you can see from outer space. Light is supposed to keep flashing even when it is fully charged. Very annoyed that they changed this feature.
Jun 09, 2014 | Shark Navigator Freestyle Stick Vacuum -...
Shark Navigator blowing front filter out of the vacum cleaner.
Dear sir, This is the most likely cause of this problem: Be sure that the top tabs and the bottom lock clip are not damaged. (red arrows on photos of my own unit) These hold the filter in place. If damaged you may try several layers of super glue, or oder replacement part from shark.com parts for this model. good luck.
May 19, 2014 | Shark Navigator Bagless Upright Vacuum
I cannot remove the brush roller on the Shark Navigator Lift-Away. It has thread caught in it that cannot be removed without actual removing the brush roller.
Hi, it's Ambrai from Crucial Vacuum.
Your Shark NV22 has small wheels underneath the head of the vacuum that need to be popped out. The wheels hide screws that need to be taken out along with the three other visible screws. Using a flat and sturdy object, pry out the wheels. After unscrewing all of the screws, you will be able remove the cover and access your brush roller.
While you're repairing your Shark NV22, why not replace your hose and/or filters? For optimal performance, it is recommended that you change your filter every three to six months.
You can purchase direct your replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=nv22&order=relevance&dir=desc
Ambrai Brown
Apr 26, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
Shark Helmet NV22L Shark Navigator Upright Bagless Vacuum Logo
23 people viewed this question
Top Shark Helmet Vacuums Experts
Think Crucial
Think Crucial
Dennis Key
Dennis Key
Are you a Shark Helmet Vacuum Expert? Answer questions, earn points and help others
