Question about Maytag Washing Machines
Maytag Washer Mod #MTW5630TQ1 10 months old-water level problem.
During last few days, upon loading the washer and trying to set the proper water level, I noticed that the water level control dial was not responding/feeling right. Last night, trying to do a load, the water level was not responsive at all and the machine just kept filling up with water until I pushed the timer control off in order to stop think the machine would have kept filling up to the point of spilling over the tub onto the floor of the Appreciate any and all help.
  • 1294 Answers
SOURCE: kenmore front loader keeps filling water in drum and will not stop
Plug off the wall. Open up behind, you will find a thin tube going from the pump area to the control point. This is the water level tube; untie this tube from above & blow into it, it should be free, if not free remove the blockage, see that it is not twisted, insert carefully. Or replace. This shd fix your water level problem.
Rate if helped pl..................
Posted on Jan 13, 2008
  • 96 Answers
SOURCE: washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Posted on Mar 31, 2008
  • 51 Answers
SOURCE: Lower washing machine function inoperative in Maytag stackable
This is very odd, and probably isn't going to be any help,,,, but i know that most top loading washers have motors that spin in 2 directions. 1 direction engages the transmission/gearbox which than makes the agitator go back and forth while also turning the water pump in a direction that actually sucks in air, or water. When the motor spins in the other direction the transmission/gearbox engages so that only the drum spins and the water pump now does its job and pumps out any water in the drum before and while its spinning. With this in mind, and the fact that you say the washer only spins,,,, its possible that the motor is only spinning in one direction allowing the washer to drain and spin,,,, but not agitate.
Posted on Mar 13, 2009
  • 298 Answers
SOURCE: water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
Posted on Mar 26, 2009
huuum
  • 750 Answers
SOURCE: Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Posted on Apr 03, 2009
I have a maytag top loading washer. the washer if set to medium load or large or super large load only fills to the half full level,
My maytag has a rubber tube that goes from the bowl up to the level sensor. I would try removing this tube and blowing it out to make sure that it is clear and not perished.
May 26, 2015 | Maytag Washing Machines
Pressure switch?
sounds like you are having a syphoning issue. caused by having the drain hose too far down the home standpipe. very common problem. test..fill the machine, high water level. when it stops filling turn off. advance into spin/drain for just a moment and shut off. listen to hear water still going down the drain.
repair.. raise the drain hose nearer the top of the stand pipe. also do not tape/seal the hose into standpipe. it has to breath. good luck. kihm washing machine drain hose installation Google Search
Jun 13, 2017 | Maytag Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Water remains in the bottom of my front load Maytag washer after a wash cycle is completed. It is causing mold on rubber gasket and a bad smell in clothes.
You need to make sure your washer is properly leveled so it can drain as much water as possible at the end of the wash/rinse/drain cycle.
You want the washer level from the front to back edges and from side to side. You'll need at least a torpedo level, or better yet, a 4 foot long level to get the best possible results.
The washer feet at the front and back that can be adjusted to bring the washer to the proper, level on all corners.
As a side note, I also find that leaving the door slightly open after you're done doing laundry, will help eliminate water getting stagnant and causing the strong odors you're experiencing.
Here's more info, I've provided in another one of my solutions for you to read through so you can better control the problem you're having and get rid of the smells.
This can happen with any front loading washer, regardless of the manufacturer.
One of the first things to do is make sure you're using the He (High efficiency) laundry detergent and only use a small amount, about 3 tablespoons or less. The trick is to not use so much detergent that you start getting a buildup in your machine. Also, if you have heavily soiled clothes, pre-treat them instead of adding more detergent to your wash cycle. This alone will result in better results.
Also, be certain the washer is properly leveled in all directions and to make some slight changes in your wash day schedule.
By making sure the washer is properly leveled, it will operate better and help minimize odors, as the spin cycle will get more water out, etc.
The other tip, that has really helped in our house, is to do all the hot water (whites) as the last load. Since we do use bleach when we wash our whites, along with hot water, the washer's last load will have had the best sanitizing cycle run through it before being left for the next load another day.
With the bleach and hot water, the washer gets a nice clean disinfecting wash which helps eliminate odors, germs, excessive soap, etc. and leaves the washer fresher. By doing this, we don't have to purchase other (more costs and expense) additives to run through the washer to attack the odor causing germs and gunk.
What good is a more energy efficient washer if I have to always run a special tablet/liquid cleaner in it each week without any laundry in that wash load? Seems wasteful to me to be doing an "extra" wash just to wash the washer. So I'm not a proponent of having to always use another product every week or month to have a washer work like it should.
However, if you've got an existing (smelly/moldy) washer presently, I would recommend that you use a produce called Whirl-Out, which will help dissolve the buildup that your machine currently has and get it clean again. Then you can follow the steps above to keep it from causing you issues in the future.
Hope you find this Very Helpful and best regards!
Sep 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
My washer is perfectly level but during the spin
if you can make it rock by hand or by jumping the legs are not adjusted proper.it can also rock if the floor is soft... then get thick plywood under the washer ....11/2 inch should be good.you should try to balance the load put heavy things in first
Aug 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Noisy washer and jumps around
It could be a few different issues. Check to be sure your washer leveling legs are set correctly. Also many newer washing machines have what they call shocks, stabilizing struts. Those can fail over time and cause your machine to be off balance and walk the floor/vibrate. When is the machine nosey? If when its filling with water it could be a water inlet valve. Or during the spin cycle it could be a drum roller, belt, pulley, Or top bearing glides to name a few things.
May 24, 2009 | Whirlpool WTW5300SQ Top Load Washer
FL message
Is it leveled properly? Is the door latched all the way? Is the water turned on at the valve? Unplug the unit for a few minutes and during that time, unhook all in/out valves and make sure drain hose is in proper position and down in to the drain hole far enough. Plug unit back in and try that.
Apr 19, 2009 | Maytag Neptune MAH6500A Front Load Washer
Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Lopsided during spin
  This can be caused by a brake that has failed.  Try to spin inner tub with washer off.  It should NOT turn.  If it turns the brake is bad and is allowing the tub to spin when agitating.  This causes clthes to bunch up.
Oct 27, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
135 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
