Question about Home
Discoloured plastic holding shower door - Home
Glue for handheld shower
If you could find out what kind of plastic the head is made of try that glue that works on that type of plastic. Different glues work on different plastic.
Dec 31, 2013 | Moen Villeta 3912ST Satine/Polished Brass...
I have a shower glass door which has three doors. One of the door always comes off when I slide d open
most shower doors are held in by the rollers some are adjustable if yours arent check to see if the spring is still holding wheels out firm if not spring probably broke
Dec 12, 2012 | Home
We have drilled a 3/16"
If you used the correct drill size, the anchors should fit in the hole by softly taping them in with a hammer. Make sure the anchors are inserted before you attach anything to them. When the screw is used with them, they will expand and hold in place.
Aug 09, 2011 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Fitting of plastic seals to bottom of shower doors Bath Store Plan Quadrant 800. These are easy enough to fit as they just slide on but when in place we cannot shut the doors!!! Do we have to trim the...
You generally put the seal in and cut it flush with the edges of the doors and then using pliers or vise grips squeeze the end of channel on to seal to hold it in place. Thank you
Jun 11, 2011 | Home
I have a sliding shower door in my bath but unfortunately, I do not know the manufacturer of it. It's about 14 years old and the bottom plastic part that is attached to the bottom of the door has broken...
there is a good chance you won't find this part for a number of reasons,...you'd be best to either change the door (with a "basco" door, great company) of if your feeling some oats, make the part you need.
Nov 20, 2009 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Need installation instructions for sliding shower door...probably #5475. When reinstalling, the inside door is swinging with nothing to secure the bottom.
not sure what you mean when inside door "swings" on a "sliding" door,...i'll assume you need the "inside door guide", a little plastic piece that screws with one screw to the main threshold,.....
Nov 02, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Need shower door replacements parts
Supplier in the Netherlands, www.novellini.nl
For the 30095PPC are the next parts:
De benodigde artikelnummers zijn:
1 x R02YOB2G-40 (set scharnieren t.b.v. één deur) à € 23,80 incl. btw.
De prijs van de bovenstaande set onderdelen is € 23,80 incl. btw.
Verzendkosten zijn € 7,50 incl. btw.
Jul 25, 2009 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Side door Plastic rollers are worn out causing door to be hard to open or close. door has begun to fall off track.
I took the cheep way out. I got a used shower door roller mechanism. (the kind that slides in tracks.) I dremmeled out the plastic rollers and then shaved them down to the right size. then took off the door and poped them right onto where the old rollers were. Perfect fix with a bit of ingenuity. 50 cents and about one hour of work.
May 14, 2009 | 1991 Toyota Previa
Home Logo
24 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
