HP 12c Calculator Logo
A
Anonymous Posted on Apr 21, 2014
How do i square the number 4 on an hp12c - HP 12c Calculator
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • HP Master 102,366 Answers
  • Posted on Apr 22, 2014
HP Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442935
Points
622693
Use the x^2 function on the g-shifted '*' key (multiplication). Press 4 g *
Alternative, just multiply 4 by 4.
  • kakima Apr 22, 2014
    Sorry, only the Platinum has the x^2 function. Just multiply 4 by 4. Press 4 ENTER *
How to calculate square root on hp12c calculator
Hi, according to the user manual:
Square Root. Pressing gr calculates the square root of the number in the display.
Link for manual attached. Trust this helps. http://www.hp.com/ctg/Manual/c00363319.pdf
How can I fix HP12c when keys do not respond?
HP lists on their site (and in user manual) a way to run a key test to see which keys are bad. I'd start there.Type "hp 12c key test" into your search window on your browser and the first thing that comes up should answer it. Took me about 4 seconds to find this.
How do you calculate square root on HP12C?
Use the square root function. It's the g-shifted function of the 1/x key (second key from the left on the second row).
How to calculate a square root on HP12C
Use the square-root function. It's the g-shifted function of the y^x key, leftmost on the second row. For example, to calculate the square root of two, press 2 g square-root
1.2124 to the 1/4 power hp12c
Press 1 . 2 1 2 4 ENTER 4 1/x y^x
2answers
A window glass 4 ft. 2 in. by 2 ft 10in. find its area. show the figure
Below is calculation of window glass area :
4.167 ft '------------------------------------'- ' ' ' ' 2.833 ft ' ' '------------------------------------'--
Total area = 4.167 ft x 2.833 ft = 11.81 ft2
3helpful
I cant figure out how to get the square root of a negative number
The square root of a negative number is an imaginary number, and the TI-30XA does not deal with imaginary numbers.
However, the square root of -x is equal to i times the square root of x. So, to calculate the square root of -4, for example, press 4 square_root = and read 2. Thus the square root of -4 is 2i.
Find missing number in this progression: 15 26 34 51 ? 84 96 125 [email protected]
The missing number is 61.
Look at perfect squares: (1,4,9),16, 25, 36, 49,64, 81,100,121
Then look at the given progression 15, 26, 34, 51, x, 84, 96,125
Take differences from the closest -1,+1, -2, +2, -3, +3, -4, +4
(15 is 1 less than 16 = 4 squared,
26 is 1 more than 25 = 5 squared,
34 is 2 less than 36 = 6 squared,
51 is 2 more than 49 = 7 squared,
61 is 3 less than 64 = 8 squared,
84 is 3 more than 81 = 9 squared,
96 is 4 less than 100 = 10 squared,
125 is 4 more than 121 = 11 squared)
3helpful
Hi, I have an HP12C and for some reason the
Turn the calculator off. Hold down the period (decimal) key and hit the "ON" button at the same time.
k24674
Grand Canyon Tech
Grand Canyon Tech
