Question about Mackie Thump Series TH-12A 12" Two-Way Compact Powered SR Speaker -
Powers up but no sound
When I power the speaker I do not have sound coming from the speaker.
How do I find out why my peavey LTD 400 has no sound...it powers up, but no sound
Check the speakers for continuity. If the speakers are OK, the amop needs to go to the shop.
Jan 04, 2015 | Peavey Music
Polk audio sound bar 4000 comes on no sound
try to re-installing the driver .
if not solved , may be the speaker damaged .
May 25, 2014 | Polk Audio SurroundBar 4000 IHT Virtual...
Peavey PVi 4B - No sound
First, Power Supplies, regulators, condensers.
If not, and you get a POP, probably your Output Transistors (MOS ?) are pulled to one of the voltage rails. Change these.Check for shorts on them or blown ceramic resistors (square white thingies) close to them. Luck !
Mar 04, 2014 | Peavey PVi 4B 4 Channel 100-Watt Powered...
No sound out of Behringer BXL3000 speaker
Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
May 04, 2012 | Behringer Ultrabass Bxl3000
Where is the radio fuse located in a 2002 toyota echo? because my radio will power on, but no sound comes out.
If the radio powers on, the fuse is OK. You probably have a bad output section in the radio.
Jul 25, 2011 | 2002 Toyota ECHO
Rockford Fosgate T15004 The Amp still powers up with the
Check you inputs to verify you have a signal coming in, if signal then check outputs try a speaker that you know is working and plug it in if that speaker plays then the subs/ or speaker wiring is bad, if it doens't play then you probably have a blown output transistor on the amp or possibly a terminal ground/positive has come loose on the inside..
Oct 27, 2009 | Rockford Fosgate T15004 Car Audio...
Same issue -very little sound coming from two of the speakers
Negitave, the problem is your receiver. Speakers only work when there's enough sound being amplified. Your receiver is what powers out the sound. Open it up and check for loose connections. Even cleaning it out sometimes helps.
Sep 16, 2009 | Audio Players & Recorders
I have a pioneer 5.1 channel surround sound system and it powers up and everything seems to go fine but you go to turn it up and no sound comes out of the speakers already checked speaker wire connections...
Does the protection relay click 3 to 5 seconds after initial power on??? If not, your unit is staying in "protect" mode to save your speakers because the output transistors or output IC is shorted and sending 40 to 60 volts at your speakers. Not a good thing, but at least it saves your speakers.
Good Luck!
barneyluc
Oct 03, 2008 | Pioneer Audio Players & Recorders
No sound comes out of speakers
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
May 22, 2007 | Dual XDM6825 CD/MP3/WMA Player
Mackie Thump Series TH-12A 12" Two-Way Compact Powered SR Speaker - Logo
35 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
