Question about Starrett 689-1Z 63706 - 689-1Z No. 689 689M Series , Countersink Gages, 100, .020-.170" Range with Case
Starrett countersink manual - Starrett 689-1Z 63706 - 689-1Z No. 689 689M Series , Countersink Gages, 100, .020-.170" Range with Case
How do i shut off my starrett electronic slid caliper?
Hello there
From the manual here
http://www.starrett.com/docs/other-downloadable-resources/798-electronic-slide-caliper-user-manual---form-951.pdf?sfvrsn=3
Automatic shut off of display after 30 minutes of non-use
Reactivation of display with movement of slide with no
loss of position
Sep 24, 2014 | Cars & Trucks
Changing the location of the decimal point on digital Starrett Internal Mic's
im not too sure what your asking, all imperial starrett id mics read 3 place decimal you will have the inch number that is set by you for the job and then the mic gives you the next 3 numbers IE 4.250
Jun 06, 2014 | Starrett Measuring Tools & Sensors
Need Starrett 682EMZ Saw Tension user guide
I can't find any available manual. I have an Starrett tension guide before but It was an old model and I don't even have manual for it. Did you try calling Starrett? They might can send you one.
Aug 13, 2013 | Starrett 682EMZ 60000psi or 4000kg per Sq....
Shut down starrett 733
On some Starrett calipers, there is no way of turnig them off, which means about once a year you have to replace the battery. sorry
Jan 22, 2013 | Starrett Electronic Caliper
How do you change batteries in the starrett 3752 heighth gage. I dont have a manual or intruction book
Hello rdm56us, Sorry for the delay but copy the follow link for change your battery, you have need 2 CR2450:
http://www.starrett.com/docs/user-manuals/3752-electronic-height-gage---form-578.pdf
best regard
Apr 28, 2011 | Starrett Garden
How do I calibrate a Starrett model 449 depth micrometer?
Try the starrett web site. You can chat with them there about it. The adjustments are fair easy to do.
http://www.mytoolstore.com/starrett/micro029.html
Nov 12, 2010 | Starrett 50443 12 Machinists' Improved...
Starrett heigth gage instructions
Here is a link to starrett's how to read a vernier height gauge article
http://www.starrett.com/download/251_p122_125.pdf
Give them a call the parts department is very helpful and reasonably priced.
978-249-3551
Dec 27, 2009 | Starrett Measuring Tools & Sensors
How do you replace the bubble in a starrett 98 Level
Contact me at Starrett and I can email you the instructions on how to change the vial only if you want. The other option is to purchase a new tube and plug assembly (the silver tube with the vial). That is much easier to do. After, you can always send the old one in for repair. Third option is to send out the tube and plug assembly to be repaired.
Most people will change the vial only the first time, after that they go with option 2 or 3.
My email is pnault@starrett.com
Starrett Tech Support
May 04, 2009 | Starrett 50443 12 Machinists' Improved...
Starrett 689-1Z 63706 - 689-1Z No. 689 689M Series , Countersink Gages, 100, .020-.170" Range with Case Logo
37 people viewed this question
Top Starrett Measuring Tools & Sensors Experts
ray gallant
Mark Schmit
Mark Schmit
Are you a Starrett Measuring Tool and Sensor Expert? Answer questions, earn points and help others
