Question about Sanyo SR-981 Top Freezer Refrigerator
What are the dimensions for the Sanyo SR-981 - Sanyo SR-981 Top Freezer Refrigerator
I want to remove the freezer tray from SR-2570M. Can this be done without removing the refrigerant?
No. The freezer "tray" is the evaporator, and therefore, the most important part of the unit. (this applies to most mini-fridges out there)
Mar 23, 2016 | Sanyo Sr-2570M Refrigerators & Freezers
Where can I get a gasket for a Sanyo SR-981?
Check with a local appliance parts supplier.
Mar 28, 2015 | Sanyo Refrigerators
We get water in the fridge all the time
There is a tube the drains the defrost water to the bottom drain pan, I would guess that it is plugged with what I call goo, its water and dust that blocks the hose or tube, you might have to take the bottom panel out of the freezer compartment and clean it out, I have also had them blocked by ice, to much ice the to get the unit back working quickly you can speed up the thawing after you clear the drain, use hot water to cut the ice.
Jun 27, 2011 | Sanyo SR-981 Top Freezer Refrigerator
Punctured evaporator on my Sanyo SR-2570 fixable?
Unless you know someone that can replace the evaporator and regas this unit very cheap as it's a major job, I'd say it's alot cheaper to buy a new one. cheers
Oct 30, 2009 | Sanyo SR-2570 2.5CF Mid-Size Dorm...
Sanyo SR 3620W countertop height refrigerator repair question
yes it can be repaired but it might cost you more than a new one. check with local refrigeration company on quote before they come.
May 09, 2008 | Sanyo SR-3620 Compact Refrigerator
Where to buy Sanyo SR-366 parts? I need a freezer door.
I will probably have one, I'll look to see if it can easily be removed.
Apr 03, 2008 | Sanyo SR-366 Compact Refrigerator
Broken glass shelves- SR-4433S
you would have to order them from sanyo at www.us.sany.com
Oct 20, 2007 | Sanyo 4.4 cu. ft Counter-High...
Sanyo SR-981 Top Freezer Refrigerator Logo
46 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
