Question about Lag Tramontane T200D Dreadnought Acoustic Guitar
Lag T200ACE bridge saddle repair - Lag Tramontane T200D Dreadnought Acoustic Guitar
My boy has an esp ltd ax 150 bass which has broken E strings at the bridge since new almost 1 a week the bridge was modified by a Luthier which worked for a small amount of time then the problem came
You friends bass has a burr on the saddle. take a small fine file and go along the pacth of the string...Go over the saddle and slowly file lightly..This should get rid of your problem...take it to a service center if you arent comfortable doing this
Apr 08, 2013 | ESP AX-414 LTD 4-String Electric Bass...
Strings slide off the bridge when bending notes on epiphone swingster, is there an upgrade for the bridge
Most likely the slots in the saddle just need to be recut. Any local guitar shop can help you out.
Jul 20, 2012 | Epiphone Emperor Swingster TBK
How do I slip a shiv between neck and body to raise action
Might want to rethink that....to raise the action is to have the strings higher off the fretboard....if you shim the neck in relation to the body, you'll actually lower the action. To raise the action you need to raise the height of your bridge/saddles. If you want to lower the action and the bridge/saddles are as low as they can go you could remove the neck and insert some card - might have to do some trial and error but to my mind...to shim enough to significantly lower the action, would take a thick shim and you might not get a good tight fit between neck and body. You might actually need a truss rod adjustment - not an amateur adjustment.
Mar 25, 2012 | Music
Belly and the bridge wont stay glued
Probably using wrong glue. For instance, using super glue is ridiculous as it is brittle and will break instantly. You should probably take this to a Luthier to have it setup. It should not cost that much for the repair and properly setup.
Apr 18, 2011 | Lag T200 DCE Acoustic Electric Guitar
High action even though neck is straight. I have also messed with the bridge saddles and not much has changed except it gives fret buzz when i lower the saddles just a little bit. Is high action a common...
Sounds like you need to get it intonated. Take it to your local guitar shop tell them your problem and where you'd like your strings to sit or that straight neck of yours won't be like that for long.
Good Luck, Cody J
Dec 14, 2010 | Ibanez ATK300 Electric Bass
New flying v, 3 strings make rattly sound near end
Are the strings hitting the frets and making a buzzing sound or is it actually coming from the bridge? Make sure the saddles on the bridge are secure. If the buzzing is caused by the fret then adjust the bridge height and/or truss rod. If the buzzing is coming from the bridge and cannot be cured it may be worth investing in an aftermarket bridge.
Jan 08, 2010 | Coffin Case 300VX Flying V / EXplorer...
Acoustic Guitar - Poor Sound Quality/Tone
might just be the pickups and their age. or a faulty cable
Apr 02, 2009 | Washburn Music
Own Peavey Cirrus 5 BXP , Strings are to close to the frets.
If the problem you are having is buzzzing, yes. This height is called the "action" of the bass. You can change either or both the saddle and bridge. I would recommend that you have this examined at a music store to verify that the neck is straight and does not need adjustment too. This is part of normal upkeep for these. Expect an overhaul cost of about $50 if you have it adjusted.
Dan
Mar 19, 2009 | Peavey Music
Lag Tramontane T200D Dreadnought Acoustic Guitar Logo
20 people viewed this question
Top Lag Music Experts
Vito Vacirca Jr.
Are you a Lag Music Expert? Answer questions, earn points and help others
