Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Raypak RP2100 pool heater set temperature stuck on 50 degrees
I turned on my heater today for the first time this year and the set point was 82 deg F and the heat went on. I checked it a few hours later and the setpoint showed 50 deg F and I couldn't change it by pressing the touch pad. I removed the board and reseated the connections but it didn't help. Is there any way to fix this problem?
I started my heater Raypak RP2100 for the first time this year. The display board lights up and the temp reads 70 and the spa is off. I press the mode button and nothing happens. Also the up and down buttons don't change the display. It just stays frozen on 70 and reads off. I pulled down the board and pressed the reset button and it goes back to 70 and off. There are two other buttons on the back of the board and when I press them they don't do anything to change the display. I can't change the display to get the heater started.
Posted on May 30, 2010
    Problem Solver:
  • 8 Answers
Could be spider webs in the orfices, which would allow the burners not to light.
Could also be a bad thermostat or pressure switch.
Posted on Jun 20, 2009
I have an RP 2100 pool heater and the minimum temperature set point is 65 degrees. Every time the pool/spa temp falls below 65 degrees, the heater automatically turns on. How can I either disable this...
Do you have an electrical switch that turns this heater on/off?
Can the heater be unplugged?
Is the heater on a separate circuit breaker that can be shut off for the season?
Nov 27, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How do you set a spa heater to heat the water over 104 degrees?
Sorry set by law and a ery good one to boot. Even if you are the one to reset the manufacture would still assume liability. Heater and thermostat manfacture would both be liable for death or stroke and they try their best to avoide this. So sorry no they have done their best to avoide someone getting hurt or dead.
Mar 06, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
How to reset a RP2100 pool heater with original pc board
up and down button and mode or enter at same time for 7 seconds
Sep 08, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool Not Heating Display Wrong
where the thermostat is located, the pump is not circulating the water
Sep 04, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
600 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
