Question about Konica Minolta DiALTA Di183F Copier
Minolta di2011 show c0000 - Konica Minolta DiALTA Di183F Copier
  • Konica Minolta Master
  • 6,674 Answers
Main motor failure remove the image unit check gear pack toward rear right side of image unit. mite have a bad motor also
Posted on Dec 30, 2015
How to remove C0000
C0000
Main Motor malfunction
- The Main Motor (M1) Lock signal remains HIGH for a continuous 1-sec. period at any time 1 sec. after the Main Motor has started turning.
May 27, 2014 | Minolta EP4000/5000 CS/PRO Copier
Develop ineo 161
hi, developer ineo 161 show thes malfuncion ebbf618a-dfb8-4d2b-b498-0e3a4f79a976.jpg
Feb 04, 2014 | Minolta BIZHUB 161F Black and White Copier
Di450 Minolta Code 2510 erreur C0000
The C0000 code is that the Fusing Unit (The HOT Part) has a motor and it can not turn or is burned out do jam or gear problems. Could not find anything about 2510
Jan 22, 2014 | Minolta DiALTA Di183 Copier
Konica Minolta Di1611/Di2011 printer Driver CD has no Driver for windows 7 64 bit - What is solution?
This is a very old post; however, maybe someone could use my help :).
The Konica Minolta Di2011 can be ordered with a built in printer module or not. The difference is that when you have the printer module, it works on PCL, but if not, it will only work using a GDI emulator.
For Win XP, you can find very easily the drivers on Konica website.
The drivers for Win7 64bit, especially the GDI Emulation for DI2011, cannot be found on the website.
I have found on the Konica Minolta website the STD GDI emulator for some other models and I have tested the one for the printer Konica Minolta 162.
It seems it works without problems for now, however I was only using it in A4 mode - manually selected. I have found that it requires a manual selection of the paper size and tray as it will not switch automatically.
I hope this helps.
BR S.H.
Mar 06, 2012 | Konica Minolta Office Equipment & Supplies
Di2011
Hi, what is the problem with the Di2011?????
Sep 15, 2011 | Konica Minolta DiALTA Di200 Copier
Probleme C0500 in konica minolta Di 1611
Hallow my friend that error is the problem of heater temperature try to check your voltage if is lower check were the voltage lost, or measure your heater lamps may be is fused, try to check all suggestions
Thanks
Jul 19, 2011 | Konica Minolta Di2011
Error code c0000 in bizhub 210
Error code c0000 means imaging unit drive motor is not working or imaging unit get hard so its better to call a service representative.
Jul 07, 2010 | Konica Minolta bizhub 180 All-In-One...
Konica Minolta DiALTA Di183F Copier Logo
44 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
