Question about Kenmore Washing Machines
My Washers did not supin but water can drain. model # 92581210 serial # CD4624387
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Why is my washer letting water escape at drain hose when filling but stops when it starts to agitate
highly normal for top loader model washers of the old age since it is relative to the level of water being placed into the wash basket of the washer and only drains as the drain pump is being used
Apr 22, 2017 | Washing Machines
What is the supine position
The supine position (/s??pa?n/ or /?su?pa?n/) means lying horizontally with the face and torso facing up, as opposed to the prone position, which is face down. When used in surgical procedures, it allows access to the peritoneal, thoracic and pericardial regions; as well as the head, neck and extremities.
Oct 26, 2016 | Body Care Health & Beauty
Whirlpool Cabrio Washer fills but will not do anything else
1. Remove the drain hose from the drain and try to drain the water from the washer. To do this plug the washer back in and attempt another drain cycle. If water does not come out of the drain hose then you now know that the plumbing is in good working order. 2. Place the drain hose back into the drain and remove the washers cabinet.
3. You will now be able to see the pump and it should have two hoses attached to it.
4. Disconnect the hose coming from the basket. If water comes out you will know that nothing is clogging the basket.
5. If both of these tests come out good you now know that the problem is the pump.
6. Make sure you write down all relevant information such as the washing machine model and serial number.
7. Head to your local hardware store and buy a pump (they typically run about $15.00).
8. Remove the old pump and install the new one (make sure the washing machine is turned off and unplugged).
9. Test it. Let it run through a cycle to make sure everything is installed and working properly.
10. If it is still broken call a repairman or ask a handy friend to check it out for you.
Sep 20, 2012 | Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top...
Washer will not drain completly need to remove agitator but how? Model number JU020000 serial # MC 4207348. Thank-you.
On most washers the agitator has nothing to do with pump out.
Most washers have an electric pump, a belt driven pump, Or a pump attached to the motor. themobilian_1668.jpgthemobilian_1669.jpgthemobilian_45.gif
The newer models have a pump filter that needs to be cleaned from time to timethemobilian_1672.jpgthemobilian_1671.jpgthemobilian_1670.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 03, 2011 | Hotpoint Kitchen Ranges
Washer stops after wash cycle, does not cool down and drain water. I turn the knob to rinse it starts up again but does not drain the water. Help
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers. Series numbers (70, 80, 90) only designate the number of "Bells and Whistles" that a washer has and don't reflect the model number.
See the following for where to find the model number:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=21&osCsid=c73289e58485c8752675ae1a35ff796b
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Jan 13, 2011 | Kenmore Washing Machines
Kenmore h2 error code
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Jan 11, 2010 | Kenmore 46462 Front Load Washer
Washer wont spin or take out the water
Hi 1st remove cabinet by removing 2 screws securing the console to the cabinet top.pry clips at corners and remove .you should now be able to pull cabinet towards you and separate it from chasis .motor /pump at center front bottom.plastic plug on right, wiggle that plug with washer in spin probably bad connection in plug.red/black wire Hope this helps please rate my solution. :)
Jun 26, 2009 | Kenmore 24032\24036 Top Load Washer
Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washing machine
Marrr
Ingllis washers have a bad habit of picking up socks, small items anyway in the drain protector hose, slows down water flow but ensures the items dont get sucked into the impeller.
from the underneath you shhould be able to see a clear cup sized container with a hose in the side, held in with hose clamps. check if this is filled with any clothing, undo the hose clamps and you should bew able to empth the cup with fingers
Apr 06, 2008 | Kenmore 24902 Top Load Washer
Neptune washer front load
I don't know if this applies to your washer, but the model #MAH9700 and a serial number from 10188468GA through 11683946GJ washers have been placed on a recall. To find out more, go to:
http://www.repairclinic.com/0098_11.asp
Oct 12, 2007 | Washing Machines
Washing Machines Logo
29 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
