Question about Air Ride Management 1996-2003 Renault Megane Scenic Plug and Play Air Suspension Kit
.renault megane scenic 2002
Auto box light comes on on the dash when it changes into top gear now and then when you turn off the engine and restart it .is okc
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 136 Answers
Take it to an Automatic service center and get them to service the transmission and fix the light
Posted on Jul 28, 2015
About gear box renault scenic megane hard to change gears
Sounds like you have a badly worn clutch plate. Have shop confirm this.
Apr 30, 2016 | 2005 Renault Scenic 1.6
Want to get radio code for my 2002 renault megane scenic
Try gumtree.com, search radio code, they email codes from serial number!
Jan 04, 2015 | Renault Vehicle Parts & Accessories
I change my transmission in 1997 honda civic freio I change the cvt to a manual transmission andengine check light stay on what could cause that to happen
Check engine lights report faults in engine AND gear box(auto). If you have changed from an auto to manual gear box then the sensor system for the gearbox is recording a massive fault with the gearbox that you have to check out. Talk wit an accredited auto electrician as to how to neutralise the system so that the light only checks out the engine.
Oct 10, 2014 | 1997 Honda Civic
Fuse blown in fuse box under bonnet on 1999 renault megane scenic
it looks like an interior light or if fitted an undef bonnet light check to see what lights are not working and check for earth if not reply an i can investigate if you have more info,just a thought its not a LPG conversion is it ?
Mar 05, 2014 | 1999 Renault Megane
Vauxhall astra 1.8 auto will change up the gears starting off but when in d4 wont change down have to put it into 3 2 1 manually aalso the light with the spanner is on
take the vehicle to your local fault code reader and plug the vehicle in to diagnostic equipment and go into the gear box control unit just like the E.C.U but for the gear box this should tell you any faults if this does not come up with any thing then try draining the oil and refilling with fresh I have known auto boxes play up just from old box oil if you are saying you hav a light on the dash then to save your self time messing with gear box oil (witch has a really nasty smell) get it plugged in first to eliminate electrical faults first hope this help good luck
Aug 24, 2013 | Cars & Trucks
Bmw e36 1997 stuck in high gear and enhgine warning light on
Most likely a shift solenoid in the transmission.
Mar 28, 2013 | Cars & Trucks
I have a 12/2000 grandure, it sticks in 3rd gear of the auto trans, but only when it has warmed up, u can reset it by stopping turning the ignition off and re starting, but only until it hits third gear...
Time for a gearbox oil change. As the oil gets older it breaks down and that means it heats up too quickly, meaning it will not allow the auto to change gears properly. As you have switched the engine off and restarted it tricks the ECU into thinking that the gearbox oil is cold until it reaches too high levels.
Change the oil soon as an auto box rebuild isn't cheap.
Hope this helps.
Apr 04, 2011 | Hyundai Sonata Cars & Trucks
I have a toyota 2000rav4 the problem is since it has automatic transmission it seems to be lacking power but still does fine in acceleration when ever running on long plain distance have trouble climbing
Well sorry to tell you but all Rav 4s have bad fuel comp and the auto matic gearboxes will not run in top gear untill the temp gauge reaches approx 28 deg as it is programed that way and some times will stay in 3rd gear once it changed down to 3rd from top, but if it gets into top {2400 rpm } 75 kph
due to the 4wheel drive.
But due to haw many KMor Miles it has done and how its been serviced as the auto gear boxes do have problems and can give the same problems pulling up hills, but its due to the Auto box But make sure the O/D button (over/drive) is off and dash light will come on the dash.
Nov 30, 2010 | 2000 Toyota RAV4
Renault megane scenic monaco 1.6v 2.0 sunroof stuck open
usually take off central interior light located above rear view mirror you should see a rounded fixtue looks kind off like a straight screw driver connection u might use this item with a screw driver and turn this should close and also open it
May 26, 2010 | 2002 Renault Sportwagon
Air Ride Management 1996-2003 Renault Megane Scenic Plug and Play Air Suspension Kit Logo
157 people viewed this question
Top Air Ride Management Air Tools & Compressors Experts
Mr R D Cochrane
Mr R D Cochrane
Andrew Taylor
Andrew Taylor
Are you an Air Ride Management Air Tool and Compressor Expert? Answer questions, earn points and help others
