Question about Acer Aspire One PC Notebook
How to connect acre netbook to brother wireless printer
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
Install printers
What OS are you using? Win 7? Is the Printer and the netbook on the same network? Setup the Printer on the Access Point/wireless device that the Netbook is connected to, make discoverable, turn on wireless, on the Netbook, Start menu, Open Devices and Printers, click on Add a Printer, All a Network, Wireless printer, follow the setup. Take a look at this vid: http://www.youtube.com/watch?v=ogUtDfaB5ms
Sep 23, 2013 | HEWLETT-PACKARD HP Mini 1103030NR Netbook
Is it possible that I can connect my BROTHER DCP-J140W printer to my dell inspiron mini 1012. Please help me with the procedures.
Yes, the printer has USB and wireless (requires a router) connections. There is a CD with software / drivers included.
Oct 25, 2012 | Dell Inspiron Mini 1012 Netbook...
How to connect hp pavilion to brother mfc9560cdw without router
This model Bother printer has a 10baseT LAN connection and can be connected to your LAN network and to your HP laptop via the wireless router. Connect a LAN cable from the printer to the wireless router.
To print from your HP laptop, check the IP address range your wireless router issues to your wireless network, it maybe 192.168.1.*** then configure the brother printer with a fixed IP address with the same IP address range but higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the Brother printer driver normally.
Then configure the Brother printer Properties.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Brother
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Jul 07, 2012 | Brother MFC9560CDW AllInOne Laser Printer
Brothers MFC490CW won't print
try and shut down the printer by holding down the power button for a few seconds, then turn it back on. You can also try rebooting the router. You have to do that sometimes because it has the automatic sleep mode.
Aug 25, 2009 | Brother MFC 490cw Color Inkjet...
Cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
Apr 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printing remotely from laptop -- can I?
I assume it's a Brother printer not your brother's printer right? I have an HP and it's a wireless printer which is accessible through my network, you have to install the printer driver and software on to the other laptop that is connected wirelessly to your network.
Mar 31, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
