Question about FAIP 1500 PSI Electric Power Washer
Change the wand - FAIP 1500 PSI Electric Power Washer
How to change tools on black & decker wizard rotary tool with flex wand
Hold the lock in on the unit, loosen the collar on the end of the wand and change the bits.
Aug 13, 2014 | Tools & Hardware - Others
Chimbali m1 water
Maybe the machine needs a cleaning. White vinegar usually works pretty well.
Jun 13, 2014 | Espresso RMI La Cimbali Espresso Machine
How do I fix a wand that won't fully retract and sticks out of the bottom causing me to loose scuction?
Hello Collet .
First I would check the hose at the bottom of the machine to see if its blocked , then I would take off the pipe at the base of the machine and then push a pole through it to clear any blockage also take the wand out completely this should solve the problem.
also goggle the make of the dyson vac and get an exploded view of the parts and you'll see how they fir and can then be replaced or new parts bought etc
hope this is of assistance
May 27, 2014 | Dyson DC25 All Floors Bagless Upright...
Change battery
Pull the wand apart, remove old batteries, insert the new batteries in the proper configuration, put the two pieces of wand back together. Viola!
Mar 10, 2014 | Conair LT3RCS Ladies 2 In One Styler...
The suction works in the wand, but not in the main vacuum
Sounds like you got wraped up in your work..
You need to take the bottom plate off and expose the brush. Once you in side you can unwind the mess. You should change the belt at the same time. Good luck. DFD
May 03, 2009 | Vacuums
Windshield wipers work only with wand on high beam.
it is the main switch that the wand is connected to change it and they will work like they should
Jan 28, 2009 | 1994 Mercury Sable
FAIP 1500 PSI Electric Power Washer Logo
55 people viewed this question
Top FAIP Garden Experts
andy just round the...
Level 1 Expert
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Mister Danger
Are you a FAIP Garden Expert? Answer questions, earn points and help others
