Question about Konica Minolta DiALTA Di200 Copier
Error code cof32 - Konica Minolta DiALTA Di200 Copier
  • Konica Minolta Master
  • 6,161 Answers
Replace the image unit.
Posted on Dec 30, 2015
Como reparar error cof32
Has the developer been replaced and the F8 function run and has the counter for the developer been reset. Also the drum should be replaced. at the same time. If this was already done did the person doing it use a vacuum cleaner to remove the old developer if so the Sensor for this code was destroyed by the static electricity from the vacuum cleaner never ever use a vacuum cleaner to remove old developer
Jan 28, 2014 | Minolta Di3510 All-In-One Laser Printer
Konica Minolta di1611 indicating cof32
ATDC sensor malfunction.Enter in the service mode :
press the Utility key press STOP 0 0 Stop 0 1
select CLEAR DATA then select I/C counter and reset the counter press C.to exit press panel reset.
Feb 19, 2013 | Konica Minolta Office Equipment & Supplies
Error code cof32
ATDC setting error - COF32, run F8 & use actual value, do not reduce setting value. open sie cover to reset.
Feb 14, 2011 | Konica Minolta DiALTA Di200 Copier
REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA MINOLTA BIZHUB 211.
to remove code "COF32" from your machine, simply change the developer with the new one. code will remove.
wish you best of luck............
Jun 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
My brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Tam
Apr 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Fixing code cof32
The excess toner is under cleaning blade.Posible you emptied the developer.COF 32 ATDC sensor malfunctions.Tray ATDC gain level from 155 to 168.
Apr 22, 2009 | Minolta Office Equipment & Supplies
Code cof32
I removed Drum Unit, emptied excess toner, cleaned and installed. After short start-up code cof32 appeared.
Nov 05, 2007 | Minolta Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
70 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
