Trying to remove the cover from my cd player. I already removed the screws. What else needs to be done before the cover releases from the body
SOURCE: CDP-CX300
Get a service manual or pro to get this taken care of. It's a timing issue..accordianman
SOURCE: Sony CDP-XA30ES CD Player
Try opening up the top and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, look at the back side of the optics and there should be a marking like KSS-xxx. This is the generic part designation. Any electronics supplier that supports Sony should have these.
Dan
SOURCE: instruction manual
Hi - You can download the manual from the link underlined in blue below:
cdp-ce375
Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Sony CDP-CX300 CD won't play
The rubber drive belt for the c/d load mech is streched or broken,
replace the belts there is another that drives something else so change them both while you have it open
SOURCE: Sony CDP-CX300 How To Replace Drive Belts?
The Sony call center says the two belts are the same size. Supposedly, there is a third belt "under the motor board" but I have not been able to find it. That is the 42x1.2 (4219362601). The two easy ones to replace are 421606101 and only cost 1.95 from Sony.
