Question about Bosch Dishwashers
Does nt drain
Bosch SHX46A06VC/14 does not drain, the drain hose is not obstructed.
  • 6,784 Answers
Check the following to address this issue further.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer or Control board
Replace if defective (note: uncommon problem).
Posted on Jun 19, 2009
What does E18 fault code mean on a Bosch exxcel 8 washing machine mean?
Drain error detected
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Washing Machines
Error code f:18
F18
  • Check drain pump filter
  • Check drain pump for blockage or restriction
  • Check outlet hose for blockage or obstruction
  • Check drain pump operation
  • Check drain pump wiring
Jan 30, 2012 | Bosch Washing Machines
Error code F18 for Bosch Maxx 7 Silence washing machine
F-18 means the pump is blocked.
First checkthe filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked. Make sure there's no obstruction in the drain standpipe or U-bend.
If this doesn't work, might as well change the drain pump assembly. http://www.espares.co.uk/parts?k=pump
Hope it helps. ;)
Thanks for using Fixya. A 4-thumbs up for answering your question is greatly appreciated.
Jun 04, 2011 | Bosch Washing Machines
Not draining properly (very slowly, causes error code). drain hose outside of washer is properly connected, no kinks, no obstructions. Error code "04" comes up repeatidly. After it finally drained we ran a...
The3 problem is more likely to be in the pump itself. No diagnostic except what you have jsut described. Open the outside covers and access the hose to and from the pump. More liokely on the inlet side and check the hose and the pump entry hole.
Please rate my help++++Thanks for using FIXYA
May 23, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Water in the bottom and not working
Check for a clogged drain (e.g.: via drain hose), or a water pump malfunction due to foreign obstruction (e.g.: glass, etc).
Note: If you changed a food waste disposer (kitchen sink area) and did not remove "plug" from disposer for dishwasher drain hose (assuming dishwasher drain hose connected to food waste disposer), then water cannot drain from dishwasher.
Apr 14, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Water wont drain, I have removed drain hose from back of machine run cycle and still nothing more than a trickle. I am guessing its plugged but im not sure of the best way to test or clear the plug. its a...
im a old bosch tech and your problemis in the drain pump. remove 1 screw in the bottom of the unit and you will take off the plastic door, spin propeller and remove obstruction that will do it. if this helps send me a 4 thumbs up post thanks
Feb 28, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I have to drain my washing machine through a front hole drain opening in the bottom corner of machine. Water comes out, it has been left in machine. I drain my machine every six loads. WHY did Bosch design...
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Feb 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
I have a bosch dishwasher mod. SHU43. It will not drain. I have checked the drain hose for obstruction. ?????????????????
Remove the cover below the door and carefully look inside. You will see that the drain hose is connected to a small pump. That pump may have an obstruction in it such as a little piece of glass. Unscrew it from the frame so you can check it carefully. good luck.
If there is no obstruction the pump may not be turning on. To check that you will have to run the dishwasher and listen for the pump to come on. If it doesnt come on you will have to replace it.
Jan 27, 2009 | Roper RUD5000H Dishwasher
Bosch SHY56A05UC/14
There is a pass through the lower back side of the dishwasher that also has a restraining device to prevent drain hose from being pulled off of drain pump. After passing hose through this opening, connect hose to drain pump. Note: there is another restraining device built into lower plastic housing which has a finger notch to accept hose and keeps the drain hose engaged in to drain pump by not allowing hose to back out of drain pump/ hose interface.
Dec 01, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
209 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
