Question about Amana Refrigerators
Amana fridge arb8057cw notgetting cold anymore. freezer defrosted, then realized fridge was not cold either.
Motor is running and air is coming in, but not very cold air.
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
SOURCE: fridge heller model fdh21has motor running but does not get cold
i have just purchased a float with a kitchen in it the fridge is a heller bar fridge not sure on model and for the 2nd use it is running but not getting cold or icing up the freezer what do i do to fix it it wouldnt be 10 weeks old
Posted on Dec 20, 2009
  • 6 Answers
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Posted on Jun 13, 2010
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Fan in freezer runs and is cold. No air is coming
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 17, 2010 | Amana ABB1927DE Bottom Freezer...
Top fridge will not keep cold,and no air flow is present when compressor is running.The bottom freezer chest stays cold. I cleaned the coils....what should I try next?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 01, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
The refrigerator is not cold but the freezer seems to be working ok as food is frozen
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Mar 28, 2010 | Amana Refrigerators
Freezer works but fridge side not cold
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Dec 06, 2009 | Amana DRS2462B Side by Side Refrigerator
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Aug 05, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Tfx27fhc
The most common problem is the evaporator fan motor which is located behind the back panel of the freezer and it moves cold air up to the fridge.  You will be able to hear it when you open the freezer door.  May have to hold the light switch in the freezer shut for it to come on.  If the fan is running feel for air flow out of the vent in the top middle of the fridge section.  If you don't feel air and the fan is running then the damper motor behind that vent is bad.  All of this is assuming that there is no frost buildup on the back panel of the freezer.  If there is frost buildup then it is a defrost problem.  Let me know what you find.
Oct 10, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer is working/refrigerator works sometimes
No No No. The most likely reason that the evaporator fan is not running is that it probably uses the heater circuit for its neutral feed. I.E. In order for the fan to have 230v/115v it needs a zero voltage brought back through the defrost heater and defrost stat. I know this for a fact because I just did one today and have fallen for this scenario (ie bad fan motor) before. You need to check from ground(earth) to each side of the fan motor (which is easily accessible) and then across the fan motor windings. The chances are that you have zero voltage across the motor. The fan will also not run until the temperature of the evaporator coil has been brought below 0 'C (32'F) and this can take up to 20 mins (again speaking from experience). This is to prevent snow being produced after defrost. I would advise getting the engineer to come back if you have paid him money and do a proper job. Shorts in Amanas can happen but have not come across one yet. Hope this helps.
Aug 26, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
