Question about John Deere Garden
Engine runs for a little while then starts sputtering and shuts off
3 Suggested Answers
  • 74 Answers
SOURCE: 1999 f250 soon as engie warms up a little starts
check egr valve make sure it is not being opened at Idle when warm generally you can see the rod for the valve through the holes on the valve when warm watch the valve raise rpm approx. to 2000rpm you should see that rod move up let off it should rest again at idle, If it is stuck up or if the vacuum solenoid is some how failing and letting vacuum to the egr valve at warm idle opening it will cause an extremely poor Idle, this of course may not be it but theres a good chance. if you can see inside the egr to the rod for the valve, It could help you diagnose it as an egr problem or let you know to look elsewhere
Posted on Mar 27, 2010
swoop611
  • 488 Answers
SOURCE: engine starts and runs for
IAT sensor is the Intake Air Sensor.. It could be temperature or amount and as the engine is stalling, I would suspect that the sensor is not measuring the amount of airflow correctly..Substitute a known good unit as these sensors are not a repairable item..
Posted on Aug 12, 2010
After start it backfires, sputters then runs
Hi,when starting bike you put the chock on,remeber this is to make a richer mixture for cold start,so when you start the bike put put the choke off a little bit as it warms up,other wise wat you are doing is couseing it to floud,so again as the bike warms up put the choke off little bit at a time,all the best.
Sep 01, 2015 | Honda VT 1100 C2 Shadow Sabre Motorcycles
02 mitsubishi lancer oz rally automatic and when I turned it off the engine sputtered a little so I turned it back on started up back fine and shut it off and it sputter again Its neverdone thisHelp?
I think what you are describing may be "run on" or Dieseling" which is a way of saying that an ngine with spark plugs that should stop when the key is turned off, continues to run in a rough manner. This is typically caused by glowing carbon in the cylinder, often on the head next to a fouled spark plug tip.
I would recommend changing the spark plugs and spending the $ for some "tune up in a can" that removes carbon deposits from inside the cylinders.
Hope this helps.
Apr 04, 2015 | 2002 Mitsubishi Lancer OZ Rally
My riding mower keeps shuting off after using it for a little while
try and run it with the gas cap loose maybe the vent is plugged
Apr 28, 2012 | Garden
My 01 alero will start fine amd run a little bit thrn sputters and dies. Will restart right away but the longer it sits the longer it runs. New ign coils wires plugs amd fuel press. regulator, is it the...
i would look into the idle air controll valve it controlls the idle on your car and since it starts a shuts off does it idle a little low when you start it then just stall out and shut off
Jun 11, 2011 | Oldsmobile Alero Cars & Trucks
My mercury villager start for a few seconds then shut off
is the check engine light on? This could be a number of different problems a check engine code would hopefully lead u in the right direction.I would also need a little more info on what it is doin does it run fine for a few seconds or does it sputter n misfire and will it start right right back up? let me know and good luck
Dec 30, 2010 | 2000 Mercury Villager
Engine starts and runs for a minute or so starts to sputter then shuts off. will restart, sputtering and shuts after a few minutes. code shows iat sensor, where is it located on the 2003 ford taurus
Aug 12, 2010 | 2003 Ford Taurus
When driving my kia it seems to stall but not cut out just momentarily ? and i have a light on dashboard look like a little tap .... slight noise from engine sounding a little like loose belt maybe
2001 kia sportage, 164,000, driving on highway and engine starts to sputter momentarily, then runs good , then sputters, runs best if you barely push gaspdal, to much pedal and sputters again
Mar 01, 2010 | 2001 Kia Sportage
Have to choke MTD to keep it running
check fuel pump diaphram is not streched or hard, check fuel filter for blockage, or fuel tank cap might be not venting, if none work drain and clean out carby bowl.
Jul 19, 2009 | Mtd LAWN MOWER PART # 787-01341...
Garden Logo
23 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
