Question about Kenmore 91493 Stainless Steel Compact Refrigerator
After defrosting my kenmore compact refrigerator, it is not cold anymore. the motor sounds like it's running, the coils in the back are warm/hot to the touch, there is a small amount of cool air blowing inside the refrigerator, but it is not cold anymore.
  • suejrhee Jun 20, 2009
    what is a recharge?
  • 6,784 Answers
Ok, this unit will need a recharge asap. this is the result of a low-refrigerant state.
Posted on Jun 19, 2009
Refrigerator Freezer Is Cold But Refrigerator Is Warm
Your fridge has was is called an adaptive defrost control. Not only does the period between defrost cycles change but also the time duration of the defrost cycle itself. The device is programmed to keep track of the appliance usage and how long it takes for the evaporator coil to be thoroughly defrosted. It will then calculate the amount of time required and adjust itself accordingly. If there is ice over the drain and on the bottom of the evaporator then your defrost element is working fine, that's why there is ice there. By what you've described it looks like your defrost drain is plugged up with old food pieces or plastic etc. The first thing to do is thaw out the drain completely including the drain tube which can be done by squirting hot water down it. Then blow it out with compressed air and run another few shots of hot water down it. You should see the water collecting in the defrost tray below. Once this is done plug in the fridge and let it run for a day or so and you'll probably find that it's running just fine again.
Nov 09, 2013 | Kenmore Refrigerators
Freezer has warm spots. All around freezer is hot to the touch. Compressor is hot, coils are clean, condensor fan is running.
Thats normal.
The condenser coils are located just inside of your exterior cabinet walls on the sides and top.
So the freezer gets cold inside and heat has to be released from the condenser coils.
If this is something new, you may have a problem with the defrost timer
Sep 11, 2011 | Kenmore Side by Side Refrigerator
I have a Sanyo SR-3770S Refrigerator and I defrosted it last night after turning it off and unplugging it. After it had defrosted I plugged it back in and turned it back on at a medium setting and let it...
Greetings
Do you hear the compressor running and no refrigeration? If yes, feel around the back fror the condenser coils.Near the compressor ,the condenser tubing should be very hot to the touch.If not , you have no or low refridgerant. You may have punctured an evap coil during defrost.
After 8 hours evaporator should be ice cold.
If compressor is not running it's thermostat
Was this helpful?
Aug 18, 2011 | Sanyo SR-3770S Compact Refrigerator
Ice keeps building up on the freezer floor in my Kenmore refrigerator freezer. though I have turned the freezer setting down to cold from very cold, this continues to happen
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 09, 2011 | Kenmore 64802 Top Freezer Refrigerator
The panel separating my side by side refrigerator from the freezer is hot - nearly to the point of burning. Kenmore model 10653606202
  1. check if the evaporator fan motor is running (inside the freezer)
  2. Same for the condenser fan motor on the bottom in the back of the fridge
  3. Clean condenser coils underneath or in the back of the fridge
  4. if there is a frost on the back wall in freezer - you've got the defrost problem, check defrost heater, defrost bimetal thermostat, and defrost timer
Oct 14, 2009 | Whirlpool GS6SHAXLS Side by Side...
Kenmore 52532101 side by side freezer and refrigerator not cooling - any suggestions? Doesn't appear to be frozen up.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator and freezer
Does the compressor click on and off every minute or so and is hot? That would likely be tripping on a thermal overload due to not being able to start (bad motor starter on the compressor). If the compressor is running normally and warm then you may have a froze up coil. Take the lower rear back sheetmetal cover off the inside freezer section and look at the coil. If it's frozen block of ice basically the defrost cycle is not working and the ice has blocked the air flow through the unit. (could be bad defrost heater, defrost timer or defrost t-stat). If the compressor is running normally and warm and you see no ice or even frost on the coils then you have a sealed system problem that usually means most if not all of the refrigerant has leaked out of the system (or a blockage/restriction in the system). This would be the worst case since it means a whole bunch of money to repair. Let us know what you find out and we can have a better idea on what to recommend.
Nov 23, 2006 | Kenmore 53642 / 53644 Side by Side...
Kenmore 91493 Stainless Steel Compact Refrigerator Logo
180 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
