Question about Toyota SE-06 Mechanical Sewing Machine
Toyota SE06 RS2000 manual
The top stitches are fine but underneath is a mess. I have checked the bobbin and adjusted the tension, it is now on 9, which seems a bit unlikely.
mohammed387
  • 1952 Answers
SOURCE: we need a manual for toyota rs2000 cb sewing
www.sewingonline.co.uk/instructions/toyotars2000/ -
cgi.ebay.co.uk/Toyota-Sewing-Machine-RS2000-CB-Series_W0QQitemZ300326924245QQcmdZViewItemQQimsxZ200
Posted on Jul 06, 2009
  • 1116 Answers
SOURCE: bobbin tension?
Try threading the machine with the presser foot up to see if this will solve the problem.
When a sewing machine is threaded with the presser foot down, the thread cannot properly enter the tension. No tension control of the top thread and it cannot form a satisfactory stitch.
You might be able to find a manual for your machine at sewusa.com
Posted on Mar 01, 2010
SOURCE: our toyota Rs2000 quiltmaster 50 is not picking
1.is the needle bent or blunt
2.is there a 2 to 3 inch tail on the bobbin that it can be picked up
3.is there lint or thread fragments in the bobbin aea
Posted on Jul 31, 2010
HansPP
  • 2510 Answers
SOURCE: Hi, My stitches look ok at
Sounds like the bobbin tension is incorrect or the bobbin is inserted the wrong way around. The thread should double back on itself coming out if the bobbin holder.
Posted on Feb 08, 2011
Testimonial: "Very speedy response - many thanks. It was the bobbin - the thread was loose on the bobbin. I rewound it and it worked fine. Thankyou"
  • 24 Answers
SOURCE: My top thread keeps breaking. I have adjusted the
sometimes the needle plate gets a burr on it which will break the thread when sewing. Usually 2 screws hold the needle plate on and remove those and pull the needle plate off. Take a close look at the hole that the needle travels into and see if its a little rough on both side. If so you can use a file on it to smooth it back down.
Tool Belt Diva
Posted on Jun 12, 2011
I just bought a singer stylist 9100 and its driven me to tears. The bobbin thread keeps couching through the top of my quilt, pulling the top stitches into a tight blanket stitch looking mess. I have...
Suggest you check your bobbin tension, pull the bobbin thread and if you feel it too loose, most likely bobbin thread not threaded correctly into the bobbin case tension plate. Do refer to your manual if you have one.
Jul 18, 2013 | Sewing Machines
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
here is a free manual
http://www.singerco.com/uploads/download/696_5417c.pdf
Jan 07, 2013 | Singer 5417 Mechanical Sewing Machine
My machine is a Singer Inspiration 4210. My stitch on top looks fine at first glance but it is birdnesting underneath. What should I do to correct this?
Check your top tension. It sounds like it may be too loose or the bobbin tension may be way too tight. Most likely it is the top tension that is incorrect though. The TOP tension effects the bottom side of the stitch and the bottom tension effects the top. If the top tension isn't tight enough it won't draw the thread up through the top side taunt enough and the excess underneath makes a big loopy mess.
Jul 29, 2011 | Singer Inspiration 4210 Mechanical Sewing...
The thread does not catch for the top stitch, and just bundles up underneath and turns into a big mess of threat. I was told that the tension on the bobbin needed to be adjusted. Is this right, and if...
You could try adjusting the tension on the bobbin but it rarely needs adjusting.
Have you checked that all the top tension discs are clean? Often a tiny bit of broken thread causes problems. Pull a thick piece of thread manually through all of them or prise gently open and look. Take out the bobbin case and put the hoover end in the empty space to **** out any stray threads, or shoot compressed air in there to blow it clean.
Remove the needle plate and check for broken threads underneath.
Try re-threading the whole thing and remember to keep the presser foot up as you do it to keep the top tension discs released.
I have found that a blunt needle can also cause this problem....no idea why.
Have you oiled your machine recently, perhaps something is stiff. Your manual should tell you where to oil. Good luck.
Apr 03, 2011 | Brother LS-2125 Mechanical Sewing Machine
Manual toyota sewing machine se13
This is a manual for the SE02, SE04 and SE06. They shoould be similar to your machine. I think they are all part of the RS2000 series.
http://www.aisin.fr/catalog/download//RS2000%20manual%20SD%202D%203D%20EN%20FR%20NL%20IT.pdf
Hope this helps!
Nov 14, 2010 | Sewing Machines
Need new bobbins as the ones I have are not for
Hi Karen. First, you really do need a manual for your machine. I found one at http://www.sew4less.com/browse.php?CategoryID=5&filter_brand_id=83&filter_model_id=6040&go_filter.x=27&go_filter.y=9. Sewing Parts online also has your manual: http://www.sewingpartsonline.com/viking-sewing-machine-instruction-manuals.aspx
If the bobbins fit your machine and it makes a stitch, then the bobbins you have are fine--what you have is an adjustment problem, to get the stitch balanced. (I have a little tip/hint on adjusting the balance that might help you.) Here are a couple of things to remember when you're adjusting the tension:
1. Use different color threads in the bobbin and on top to make it easier to see
2. Thread your machine with the pressure foot UP. (Otherwise, the thread may not slip into the tension disks like it should.)
3. Adjust the tension with the pressure foot DOWN. (This engages the tension disks.)
4. Move the tension dial only a little bit at a time.
Hope this helps!
Robbie
Apr 08, 2010 | Husqvarna Freesia 415
I always have problems with loading the bobbin, when I think it is loaded properly and begin sewing, it balls up and doesn't stitch properly on the back side of the fabric. Top stitch is fine, underneath...
the bobbin case has a small screw on the side for adjusting the tension, use a tiny screw driver to finely adjust the tension and sew on a scrap until the stitch looks good always turn the screw clockwise to turn the tension up and counter clockwise to loosen it
Dec 13, 2009 | Bernina Sewing Machines
Won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Jun 25, 2008 | Janome D'cor Excel 5018
Toyota SE-06 Mechanical Sewing Machine Logo
79 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
