I cannot get my Xerox WorkCentre Pro 128 to feed envelopes from the bypass tray.
Comments:
Dec 04, 2007
- I finally got it to work but I had to change the inverter setting on the copier to offset stacking. After that, I had to change the copy settings on the copier to tell it to use the finisher and I had to go into the printer driver on each PC and tell it to use the finisher as well. Without doing this everything came out into the center tray, which made the stapler and other features of the finisher unavailable.
Solution Title:
How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/SResolution/ Solution Fixed! Did not fix.
Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN.
In Microsoft Word (Word 2000)
Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
Under Printing Options, select Portrait (LEF) - Long Edge Feed
As Feed from, select Tray 5 (Bypass)
Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
Under the Paper/Output tab
Set the following features as follow:
Job Type: Normal Print
Paper Size: COM10
Output Size: Same as Paper Size
Image orientation: Portrait
Image Rotation: OFF
2 sided Print: 1 sided Print
Stapling: None
Output destination: Center Output Tray
Offset Stacking: None
Under Tray/Layout
Set Paper Source to Tray 5 (Bypass)
Click on Bypass Tray Settings
Paper Type: Heavyweight (1 or 2)
Feed orientation: Portrait
Click <OK>
" on Specify Paper Type and select Heavyweight (1 or 2)
" (Apply> and <OK>
" <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6)2006-04-05 21:57:29
Comments:
Dec 04, 2007
- Yeah Envelopes on those machines can be tricky to set up.
cannot clear document jam error. There is nothing jammed. checked everything and ran the paper...
(More)
cannot clear document jam error. There is nothing jammed. checked everything and ran the paper manually throughtout. Sharp al 1631
Having problems printing 11 x 17 calendar on Xerox 7335. Print monthly view of MS Outlook 2007...
(More)
Having problems printing 11 x 17 calendar on Xerox 7335. Print monthly view of MS Outlook 2007 calendar from MS Calendar Printing Assistant and the calendar does not fit page. It shrinks the margins of the calendar insted of taking up the whole page.
Job Status Completed with error(016-799) The Troubleshooting guide solution was: The print parameter...
(More)
Job Status Completed with error(016-799) The Troubleshooting guide solution was: The print parameter combination was wrong. Check the print data.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
