Question about Kenmore 53603 / 53606 Stainless Steel Side by Side Refrigerator
GE Stainless Steel Side by Side Refrigerator
Dirty water out of dispenser
SOURCE: Kenmore Refrigerator
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Posted on Feb 16, 2008
SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
Posted on Apr 16, 2008
SOURCE: Ice and water dispenser lock
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
Posted on Aug 06, 2008
larryyb
  • 291 Answers
SOURCE: Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Posted on Nov 26, 2008
SOURCE: cleaning tray on door where water is dispensed
the stains is from hard water.(calcium)you can get a new tray from sears.com
GSS22SGR Stainless Steel Side by Side Refrigerator. Poor ice making and when the water dispenser is pushed, the water goes out to the floor through the water valve on the back of the fridge. What could be...
The problem sounds as if either the tubing to the water valve in the back is cracked or disconnected from the valve so the water is leaking onto the floor instead of into the i/m or door dispenser.
GENE
Oct 06, 2011 | GE GSS22SGR Stainless Steel Side by Side...
Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Feb 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a side by side GE refrigerator and the water dispenser is leaking quite a bit. It looks like is leaks where the water is dispensed.
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Oct 31, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a GE side by side stainless steel refrig. the water will not dispense. How can I fix it?
Is there water to the water valve in the rear of the fridge? If yes, replace the water filter if older than 6 months or if you're on a well. You may need an inline water filter behind your fridge in addition to the one in the fridge to protect the water valve. If no, turn on the water. If you're making ice but no water dispense and you have a new water filter. Replace the water valve.
Dec 10, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Kenmore 53603 / 53606 Stainless Steel Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
