Question about Protron PLTV-32 Television
Try to put electrical tape over the keys - Protron PLTV-32 Television
    President:
  • Protron Master
  • 1,779 Answers
What are you trying to do?????
Posted on Jun 19, 2009
Replace a key actuator pad that is torn bad
The rubber key cover is one piece and not sold as a spare part. Take the radio apart, remove the pad and put a thin tape, such as a very high quality electrical tape and a small amount of RTV silicone under the tear. Reassemble, wiping off any extra RTV as you go.
Nov 10, 2013 | Motorola Talkabout T5420 (14 Channels)...
Lost key to my alxus es 400 and need to move car asap
your car should have a spare key taped to the steering column under the dash.....so, look for black electrical tape wound up around the steering post and unwind the tape....you should find a spare key there
Apr 22, 2012 | Cars & Trucks
Found key taped to ignition box under the steering colum taped to the box i untaped the key now the jeep starts then stalls and a light on the control panel with a key inthe middle is blinking and it just...
The normal key of your car has a chip in it, without that chip the security system is activated and the motor shut down - the blinking light is to signal that. The previous owner has put that key there as to use a regular/simple key, much cheaper than a chipped key . Put the taped key back where you have found it and it will all go back to normal.
Jun 20, 2011 | 1999 Jeep Grand Cherokee
I was replacing my rear blinkers , before i put electrical tape on them i tested them and all was well, added the tape tried again and lo and behold everything went dead..checked battery and it is good,...
Hi,,remove the tape and check the connections,,when you say "everthing went dead i assume you mean all lights ect,,,check your fuse box,,,more than likely the indicator wiring has shorted and blown a fuse.
Mar 24, 2011 | Suzuki DR 350 S Motorcycles
Lost the key to my partners lynx mobility scooter... 4 wheeler. Where can I buy a new cylinder / locks? Thanks!
Soutside how secure does the scooter have to be? Is it parked inside at night and does your partner leave it unattended for long? The reason I'm asking is because you can replace the keyed switch with a plain old on/off toggle switch for about 5 bucks. Just remoce the console unscrew the old keyed switch unplug the old switch from the wire harness and using the original connector splice the toggle swith to the connector tape with electrical tape and install in console. Check correct operation of the switch before you put it in the console. If it works ok install it and put the console back together and there you go a fix plus cheap too You can always call Invacare @ 1-800-333-6900 and order a new switch Hope this helps.
Oct 27, 2010 | Lynx L-3X Compact Scooter
My keys have popped up on my akai mpk 49
use black electrical tape. put tape on the edge of the key and cut it at the bottom of the mpk
Feb 21, 2010 | Music
Hi, my Brother DCP-115C Brother printer keeps telling me my black ink is empty despite putting brand new cartridges in, can you offer any help. Thanks.
Black electrical tape is the answer and it’s because the tape is BLACK. Even if u put black tape on an empty cartage the printer will still try to print.
The tape goes on the side of the cartage that faces the back of the printer (where the sensor must be).
Dec 11, 2008 | Brother DCP 115C All-In-One InkJet Printer
No Compatible media found in HP Tape Drive
Try a brand new tape fresh out the wrapper.
If that doesnt work make sure you are using the right drive in your backup software!
It sounds like a message often seen in windows backup where you have selected the wrong tape drive from the list and it just tells you "No compatible media found" when actually the drive listed isnt even connected to your system still
Nov 27, 2008 | HP StorageWorks Ultrium 448 LTO 2 Tape...
Cannot get Tape to into camcorder
Have you tried using the cleaning tape ?
Jun 02, 2017 | Sony Handycam CCD-TRV107E Camcorder
Protron PLTV-32 Television Logo
27 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
