Question about Philips Magnavox 20MT1336 20" TV
Cie-Philips Nicam 63 digital c i e - Philips Magnavox 20MT1336 20" TV
Mono stereo function
Tv Speaker; Stereo/dual Reception; Nicam Reception ...
www.manualslib.com > ... > Flat Panel TV > 141K TX > Owner's manual
LG 141K TX) Manual Online: Tv Speaker, Stereo/dual Reception, Nicam ... Stereo. Dual. Mono Sound Selection. In stereo reception if the stereo signal is weak, ...
Video Mode; Audio Mode; Still; Stereo/mono - ManualsLib
www.manualslib.com > ... > LCD-32CA9S > Owner's manual
Dec 21, 2015 | Televison & Video
Philips plasma 63pf9631d/63 has a dark screen and the colors are wrong and it will blink from light contrast to dark. what would cause this
Bad component, bad connection, bad anything. Imposibble to diagnose from a distance whit this description of the symptoms.
Mar 05, 2015 | Philips 63PF9631D 63 in. Plasma Television
I dont know how to operate the install button/ have no manual
My suggestion is to look online and try to find one there.
Aug 19, 2014 | Philips Televison & Video
Easy tv mpeg pci tuner philips saa713xhl chipset driver
http://www.tomshardware.com/forum/46697-63-philips-tuner-card-drivers-windows
Oct 09, 2013 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have mislaid my instruction manual for my VCR Philps Nicam VR620 can you send me another one
You can download the instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 02, 2010 | Philips VR620CAT VCR
My philips tv flat screen keeps shutting off and a red flashing code starts blinking?
Not sure what code since you didn't say, but here is the code breakdown.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 27, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
42PFL5532D/05
Audio from an external input only shows as mono on the TV information display.
If you are only getting sound through one speaker of the TV, check the scart connections are all in fully, and straight.
If you are getting sound through both speakers, then the sound is stereo. Stereo only shows when there is a NICAM stereo sound source, which is only through analogue terrestrial TV.
Dec 01, 2007 | Philips 42PFL5332D 42 in. LCD Television
Error message/Switching off
Hi.
What is the model number on the rear of set & chassis number if it has one.
Oct 10, 2007 | Televison & Video
Philips Magnavox 20MT1336 20" TV Logo
12 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
