Question about Broaster Pressure Fryer
How to remove slide lid for boraster 1800 model
How do I change the lid on a Cabrio washer (model # WTW7800XW2)?
If you lift the lid up and go to the base you will see 2 torx head screws on each side remove them lid will slide up an off small tip when trying to remove screws if they are tight or stubborn stop they have a tendency to rust in place you may snap off trying to remove bad design if this happens order new screws 4 and hinges they are different order left and right
Feb 12, 2015 | Whirlpool Washing Machines
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
I want to replace lid on my cabrio model wtw7800xw2 with a solid lid frame on glass lid keeps breaking
If all you want to do is to replace the lid, there are two TORX 15 screws on each side. Undo those and the lid should slide right off the pins. Be careful to not drop them into the tub or dispensers. You can then slide the new lid right on. Put the screws back on and test. If you lift the top cover off and mess with the springs, it is a PAIN to take off and put back on.
Feb 11, 2014 | Whirlpool Cabrio Washing Machines
I have a fisher and paykel dd24ph6 model that will not lock. Where is the locking mechanism located?
the way the dish drawer locks is the lid lowers onto the drawer..on the sides of the drawer are motors that lower and lock the lid into place ..to get to them the drawer must be removed,to remove the drawer remove th pins from the side of the drawer,slide down and off the front panel and push and and release the tabs that lock the drawer to the slide rails..then push the slides back slightly and lift off drawer..on the sides connected to support bracket on each side will be a lid motor. It is advisable to replace both at once
Aug 24, 2011 | Fisher and Paykel DS605I Built-in...
How do you open the casing, without causing damage, on a Maytag model # sdg305daww?
There should be several screws at the back holding the lid in place. Remove these screws and slide the lid forwards and lift it off. Remove the back cover and this will give you access to all the other sides and much of the mechanism of the machine.
Apr 12, 2011 | Dryers
The system is not reading any games
Hello there,
The reason your system is not reading any game is because the lens is not working, to fix this, follow the steps below;
  1. Unplug the power cable, video cable and controllers and remove any discs from the disc drive
  2. Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  3. Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  4. Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard
  5. Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  6. Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  7. Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  8. Replace with new laser module, reverse your steps and reassemble the PS3.
Take care
  • Step 2 Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  • Step 3 Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  • Step 4 Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard.
  • Step 5 Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  • Step 6 Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  • Step 7 Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  • Step 8 Replace with new laser module, reverse your steps and reassemble the PS3.
  • Read more: How to Repair a PS3 That Does Not Read a Disc | eHow.com http://www.ehow.com/how_5778475_repair-ps3-not-read-disc.html#ixzz0sQmwqziZ
    Jul 01, 2010 | Sony Playstation 3 (PS3) Console
    Both springs on lid broken. Lid won't stay up.
    Whatever is on the shelf (parts that have not sold yet) is your best bet. Someone in the USA has to have em cause it hasnt been that long out of business.
    here's one place to start ( i couldnt get thru)
    AJ Madison
    1416 38th Street
    Brooklyn, NY 11218-3614
    Phone: 800-570-3355
    718-532-1800
    Phone: 800-570-3355
    718-532-1800 Fax: 800-570-7805 E-Mail: sales@ajmadison.com Appliance
    Parts Store:
    800-378-5177
    Appliance parts store:
    1800- 378-5177
    hope this helps
    Mar 30, 2010 | Woods Chest Freezer C1501W3
    Fisher and paykel dishwasher
    F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
    If a flood condition is detected, both draws will activate the drain motors and flash F1.
    Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
    There are three possible scenarios for this error code;
    1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
    2. Something too tall was placed in the drawer preventing the lid from closing completely.
    3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
    Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
    Food processor
    1. Remove the work bowl completely from the base
    2. Plug the food processor in and turn it on
    3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
    4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
    5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
    6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
    7. Slide the lock to the right into the locked position
    -Tha Mp3 Doctor
    Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
    Broaster Pressure Fryer Logo
    63 people viewed this question
    Top Broaster Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a Broaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
