Question about Teac CD-P1120 CD Player
The player don't play anymore
Hi, my player doesen't play, when I put a cd insid it displays "no disc" or "Er". I tried to clean lens but with no sucess.
How can I fix it? Could it be the laser that terminate his life (the player is old)? In that case how can I solve the problem?
Thanks a lot!
4 Suggested Answers
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
  • 6784 Answers
SOURCE: Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Posted on Sep 14, 2009
  • 3 Answers
SOURCE: Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Posted on Nov 21, 2009
  • 25 Answers
SOURCE: cds skip
lens cleaner does not work use meyl spirits
Posted on Feb 28, 2010
0 characters
1 Points
MS3100 3-Disc CD Changer not recognizing CD's.
the laser on the optical pickup is not able to read the disk. either the disk is scratched (or dirty), the lens is dirty, or the optical pickup is bad and needs to be replaced. to clean, get a lens cleaner at any electronics store and follow their instructions. if it's really bad, unplug the unit, remove the cover, locate the lens, and use an alcohol pad or rubbing alcohol and a q-tip. don't soak it, but wipe the lens off gently and blow on it to dry it off (the alcohol will evaporate). this is not a recommended solution if you are the least bit unsure of what you are doing. if you need to replace it, try
Dec 22, 2009 | Emerson MS3100 3-Disc CD Changer
Cd player keeps showing nd cannot play any type of Cd at all
Hi Tony,
Your GE 7-5295 keeps showing nd (no disc), this simply means that your lens has been damaged. Please replace the lens and you would enjoy listening to music once again in your kitchen.
Kind Regards
May 30, 2009 | GE 7-5295 Undercounter DC /Radio Combo -...
The SA-1 cannot read CD and Display is off
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
Feb 04, 2009 | Marantz SA-1 CD Player
Denon cd player
Put a lens cleaner into it. Can you hear the disc spinning inside, is the laser trying to read it? How old is the player? Has it been sitting not used for any length of time? It's better to use CD players too much than not enough. Has the guarantee expired? I have a workshop in SW London if you get stuck.
Aug 17, 2008 | CD Players
JVC XL-SV22 Video CD
if cracks having in disc mean some times header does read disc! clean your header with disc cleaner!
Jul 01, 2008 | JVC XL-SV22 CD Player
Bose Wave Radio w/single CD player on top
My Bose Wave Radio/CD developed this problem about a year ago. I don't use the CD player much and kept the unit clean. The disc spins but, the system does not read it. Cleaning the lens with cotton did not help.
Read that Bose charges $75 to fix this problem.
Jun 19, 2008 | Bose & Wave& Music System
Wurlitzer 1015 OMT Disc spins, then stops....
Spoke with "Doctor Jukebox" from Folsom, CA about a similar problem I had. You can find him on craigslist.
I did NOT have the "2222" display issue.
Root cause: The laser isn't "seeing" the CD and interprets inability to see as being the end of the track, therefore, puts the CD back into the carousel.
1) Clean the lens. Be careful to use an appropriate lens cleaning solution. The lens is made of plastic and may cloud up if a harsh solution is used. Use a Q-tip dipped into the cleaning solution and gently clean the lens using a side-to-side motion, not a front-to-back motion. Wait for a bit until the lens is completely dry, then try playing a CD. (note: this fixed the problem for me)
If that doesn't work...
2) Replace the laser module. It's easy to remove with a torx. Be gentle when disconnecting and reconnecting the ribbon cable and/or other connections so you don't bend the leads. Laser modules cost a few hundred dollars, so try Solution 1) above before replacing the module.
Mar 15, 2008 | Wurlitzer Jukebox 1015 One More Time...
I works mechanically, but doesn't play the CD
try cleaning the lens first use a lint free swab and GENTLY clean the lens. don't use any liquid on this. if that doesn't work then load a disc and gently spin the disc when it lifts into load posistion. if begins to spin on it's own then replace the spindel motor. if it still does not spin, replace the optical pickup, the EF sensors inside the pickup no longer have the ability to read (see) the disc.
Feb 03, 2008 | Teac PD-D2380 5-Disc CD Changer
KOSS CD player will not read CD says '' no disc
you need to Clean the laser lines inside the cd player I can do that for you if you want me to
Dec 20, 2007 | CD Players
Won't play discs. Instead conitnuously rotates showing 20 segments per disc, no matter what.
Yanaha has had lots of bad laser pickups the past several years. It has to focus before it will spin. Sometimes they will focus and spin but still not read the disc. mybe you can try to clean the lens... CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Dec 13, 2005 | Yamaha CDC-501 5-Disc CD Changer
Teac CD-P1120 CD Player Logo
Top Teac CD Players Experts
Jaime Hernandez
Are you a Teac CD Player Expert? Answer questions, earn points and help others
