Question about Cuisinart Keurig B50 Single Cup Coffee Maker + 12 K Cups
Cuisinart keurig coffee maker failed to pump all water from the reservoir
  • 6 Answers
SOURCE: Water leaking from the base of the unit.
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Posted on Aug 12, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
SOURCE: Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Posted on Jan 08, 2009
freetek
  • 5568 Answers
SOURCE: Cuisinart COD 4000 coffeemaker
Just a comment; most of the coffee maker failures are caused by the premature failure of a thermal fuse that is intended to prevent fire in case the main heater doesn't turn off as it should. Unfortunately, most of these parts come from China and are very poorly made so the point at which they 'protect' is pretty unpredictable, many of them failing at a much lower temperature than necessary. The second most common failure is the thermal switch that cycles the main heater element; these are bimetallic switches that grow 'tired' and the point at which they open and close again gets wider apart until it can take an hour for a 12-cup pot to finish brewing.
Posted on Jul 15, 2009
When brewing it makes a loud noise
I have 2 Cuisinart Coffee makers. Both make loud humming noises during the pump cycle. In my units, the water reservoir vibrates when the pump is active. Test by hand pressure on the water reservoir when brewing.
I experimented with adhesive foam pads and they worked well but...they eventually fell off. I often just push the unit against the wall behind it.
Oct 14, 2013 | Cuisinart SS-700 5-Cup Coffee Maker
Keurig B70 automatically pumps water when turned on
Purge and Descale unit to reset the system to original state.
Jun 26, 2012 | Keurig Platinum B70 Coffee Maker
Reservoir is full - unit will not flush or brew - pump is running but no water is being pump out of the reservoir. Replacing the reservoir does no good - blue lights are continuous - no blue blinking...
Hi, Give it a couple of good slaps on the back...there is air stuck in the pump...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 02, 2011 | Keurig B60 Coffee Maker
My keurig stopped pumping water through to make coffee. water just flows back into the reservoir.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 21, 2011 | Keurig Platinum B70 Coffee Maker
B60.Coffee maker was working fine untill yesterday, now brews 1 cup and pump starts but does not pump and machine shuts off. Help me. Bill Cobb
Hi Bill, sounds like similar a problem I had with my Keurig Coffee maker. Your pump may be plugged with mineral deposit build-up from your water. Do you use regular tap water or filter it in any manner?
Have you ever cleaned the insides with vinegar? Empty your reservoir of water, and pour a bottle of white vinegar into the reservoir. Run the maker through several cycles to ensure the vinegar has worked its way throughout the ‘guts’ of your maker, and then let it sit for 2-4 hours.
Empty any remaining vinegar from the reservoir and then cycle at least two full reservoirs of water through to flush the vinegar out. When you stop smelling vinegar in your coffee cup, you’ll know when there’s no vinegar left inside.
You should probably clean you Keurig once a year, or more depending on how heavily you use it.
SWMBO tells me you’ll find similar instructions above in the Owners Manual or you can check out this link: http://www.ehow.com/how_4927372_clean-keurig-coffee-machine.html
Good Luck, I hope this helps! – Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 09, 2009 | Keurig B60 Coffee Maker
When trying to brew a cup of coffee it drips slow like it is clogged
Hi, RICHBURG511. Sounds like similar a problem I had with my Keurig Coffee maker. Your pump may be plugged with mineral deposit build-up (calcium) from the minerals normally found in your water. Do you use regular tap water or filter it in any manner?
When was the last time you de-scaled your Keurig? Empty your reservoir of water, and pour a bottle of white vinegar into the reservoir. Run the maker through several cycles to ensure the vinegar has worked its way throughout the ‘guts’ of your maker, and then let it sit for 2-4 hours.
Here’s the ‘poop’ straight from Keurig, direct. Just follow the links.
Good luck, I hope this helps! – Howard, Burke, VA
hslincoln
Dec 05, 2009 | Keurig B60 Coffee Maker
Keurig B60 won't pump water
http://www.youtube.com/watch?v=nIBvzWWI-LY
This worked well for my Platinum series Keurig. It has not failed since and I "brush" the filter under the reservoir when I change the filter in the water reservoir.
Sep 27, 2009 | Keurig B60 Coffee Maker
Cuisinart Keurig B50 Single Cup Coffee Maker + 12 K Cups Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
