Question about Health & Beauty
Broken tube fitting for danalogic I-fit81
It's The Plastic Elbow Between Aid And Tube
5 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: amana ic6 ice maker
sounds like your ice maker is working properly and that maybe you pinched the water line when you reinstalled it back into the elbow.. is the elbow clear of any ice build up or foreighn matter that would restrict the flow of water into the ice mold tray? If so..that's your problem.. ( thaw it out or melt it and then you should be OK) Hope that helps..
Posted on Aug 19, 2008
  • 175 Answers
SOURCE: How to reassemble vacuum elbow tube with plastic insert?
If the plastic insert has come off then that is not normal. It should be all one piece to the hose. You might have a hose problem that needs replacing.
Posted on Nov 30, 2009
  • 11 Answers
SOURCE: I find that my BTE open fit hearing aid solves a
There are a couple of solutions that you can try, ask your audi to fit a sport lock or change the tip he is using. If that does not work, think about investing in a set of custom made tips. A sport lock is a piece of plastic that attaches to the tubing, when you place the tip in your ear this piece of plastic is folded around the inside of your outer ear along the bowl.It aids retention of the tip.
Posted on Sep 19, 2011
  • 1632 Answers
SOURCE: Siemens Open Tube hearing aid how to stop retainer from flicking out of ear
Bend the wire to fit your ear lobe
Posted on May 15, 2012
My right hearing aid is 4 momths old and it stopped working
The Bolero model requires clear passage of sound through the tube that connects it to the dome/tip that fits into your ear. To determine if the tube is blocked, with a good battery inserted and the battery door closed, unscrew the top of the tube where it connects to the hearing aid. If you cup the hearing aid in your hand, it should whistle/feedback. If not, there is something wrong with the hearing aid. If it does whistle, your audiologist should have provided you with a thin, flexible plastic piece (often green) and instructed you how to unscrew the tube at the top of the hearing aid to run the plastic piece through the tube, all the way out the other end of the dome/tip. If that piece can travel the entire tube easily, then sound should be able to. In any case, a Phonak hearing aid has at least a one year manufacturer warranty (a Q90 likely has a three year) and they will pay for shipping both ways to fix it. You need to send it via an audiologist, though.
Jun 08, 2014 | Phonak Bolero Q90 BTE behind the ear...
B&S fuel feed pipe connector problem
Try using an easy out (special tool for undoing broken threaded tubes and fittings) or a flat blade screwdriver and stick it into where the broken part is. Try to unscrew whats left of the broken tube.
Sep 17, 2017 | Briggs Motorcycles
I find that my BTE open fit hearing aid solves a lot of problems but the fitting seems to creep away from the ear drum making it difficult to hear. I find I am continually pusshing the tube back to where...
Mar 11, 2011 | RTO 2 Siemens Pure 700 Open Fit Hearing...
Directions on installing a catalytic converter
For optimum performance, the converter must be installed so exhaust flows through it in the proper direction. When laying beneath the vehicle with your feet towards the rear, the converter should be installed so the numbers stamped into it are readable.
s Random Technology Super Flow catalytic converters are designed to fit a variety of vehicles. Special adapters may be required or special air tube adapters may be required.
s If a converter with air tubes is installed on a vehicle not equipped with an air management system, both air tube fittings must be plugged.
s If a converter is installed on a vehicle with an air management system, one air tube elbow & one plug must be used.
Plug Installation
Determine which air tube fittings (if either) are to be used to make air connection in your application. (Plug the side away from the vehicle's air supply management system.) Plug the fitting(s) not used before installing converter.
plug%20inst%20ill.jpeg 1. As in Figure 1, place converter on a secure surface with air tube fittings up, being careful not to crush the converter body or heat shield.
2. Place plug(s) into airtube fitting(s). See Figure 2 for direction of plug.
3. With a hammer tap plug(s) into airtube fitting (s) until seated. The top of the plug(s) will be flush with the end(s) of the tube. See
Figure 3.
4. Crimp the end of the tube over the plug with pliers. Crimp in at least 4 places. See Figure 4.
Airtube Elbow Installation
The airtube elbow is installed on the same side of the converter as the
vehicle's air supply management system. The remaining tube should be plugged (See above). If your vehicle is not equipped with an air management system, both tubes should have been plugged.
After installing catalytic converter on the vehicle:
1. As shown in Figure 1, insert the airtube elbow into the converter's airtube fitting.
2. Position elbow in correct direction to connect air management system and secure either by welding or by using a small clamp.
3. Complete connection to the vehicle's air management system. (An airtube attachment kit may be required.)
Plug Installation
Figure 3.
Oct 14, 2010 | Mitsubishi Montero Sport Cars & Trucks
How do you blow out the ac drain line on a 2000 Jeep Gand Cherokee?
It has a tube with a rubber elbow on it,just pull the elbow off,and there is a plastic tube that you will see,use compressed air to do this,you will find this directly below the evaporator,where the ac lines go in the fire wall.
Jun 05, 2010 | 2000 Jeep Grand Cherokee
Nov 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Water leak from ice maker
The fill line internal to the freezer is likely frozen up from the elbow inward.. When the icemaker calls for fill...pressure builds up on the plastic tubing causing it to pop out of the elbow. Check the tube inside the freezer by removing icemaker and running a long thin screwdriver or a rigid wire up into the tube until you feel ice or the plastic elbow outside.
Clear ice, if present, by squeezing hot water in from freezer side with turkey baster until cleared and water comes out back.
Aug 21, 2009 | Amana Refrigerators
Replacing a water elbow in a Fridgidare model FRS26ZRFW1. Can't pull old plastic elbow off the existing tubing. Do I need to cut and push in? The tube is coming into the ice maker/water dispenser from the...
I went to Lowes and bought a new Elbow (2.49) and cut the lower tube right at base of elbow. Upper tube slid out. Pulled a little on bottom tube and replaces easily.
Jun 15, 2009 | Refrigerators
Amana ic6 ice maker
Aug 18, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Connection for continuous discharge
There unit should have come with a small plastic tube. One end should have a thread connecion for hose hook-up. There should be an opening on the back of the unit that you push the tube through to connect with a little elbow tube inside the unit. You should be able to see the elbow connector from the front of the unit by removing the water bucket. Just push the plastic tube in from the back until it fits snuggly over or into the elbow tube and replace the water bucket. Run the connected hose to your sump pump.
Jul 16, 2008 | Dehumidifiers
Health & Beauty Logo
42 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
