Question about Earthwise 1850 PSI Electric Pressure Washer
Water leaks thru the handle? - Earthwise 1850 PSI Electric Pressure Washer
How to stop water getting inside a single leaver shower faucet?
quite possibly there is a broken O ring inside the faucet .
Jul 17, 2015 | Home
Water leak thru valve when turn to shower
a lot of shower diverters do this..you may need a bigger seal on the diverter..if you can remove the spout assembly from the tub(with the diverter valve in it) and take it all to the hardware store.. see if they have a different seal/diverter that has a snugger fit but still falls to drain the shower head line out..that will slow that leakage..the spout is on a pipe and unscrews counter clockwise(normally)unless its a single valve unit..with the wide ring around the back..then that calls for a plumber..
Jan 21, 2014 | Moen & Bayhill& Single Handle Tub & Shower...
Soap leaks thru handle
It sounds like a hose or water line has come loose.
Jul 05, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
My Dolphine 2002 works but has water inside the handle that seems to make if difficult to climb walls. Can the water be drained some how and the handle resealed?
Thank you for posting your question here on Fixya.com.
Purchase a can of spray foam insulation and then drill a hole in each end of the handle to match the spray tube on the insulation. Let the handle dry once the holes are drilled then fill the handle with the foam from one end until it begins to expand out of the holes. Once the foam has set you can trim off the excess and scoop out a dimple of foam from each of the holes. Seal the holes with a two-part epoxy but even if the handle still leaks the foam will prevent much water from getting in and the handle will remain buoyant.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Jul 25, 2011 | Dolphin Maytronics Advantage
Hello, lost water in the house, now when it came back on, water dispensor has a slow drip (not sure if related)... the dispensor handle seems to be working fine... it dispenses water when pressed.. doesn't...
remove bottom grill.
look for tube which runs thru freezer door.
follow back towards underneath of machince/ find push fit connector.
remove pipe which run thru door from connector and blow thru quite hard. reconnect and press dispenser paddle to allow water back thru
this shhould solve problem in 9/10 cases if it doesn't then you will need your water inlet valve checked
Jan 27, 2011 | Whirlpool Refrigerators
My baxi combi 100 he plus keeps losing pressure cant find a leak anywhere inside but some water coming outside from expansion pipe?
If you are having a small amount of water loss thru t&p valve then the valve may just be getting old and need relaced,If yours is a typical valve there will be a small handle in the center on the valve face. Open this valve by pulling straight back on handle end. If it's too hard to open dom' t force it. If you can open it then do so 4-5 times in a hurry ad when it closes tap on on the center of valve where the pivot point for valve handle is. Just tap it lightly and see if the leak slows down or stops. If so I would go ahead and replace the valve. Thank you
Jan 03, 2011 | Heating & Cooling
Installed a new 88976 handle but still have a leak
replacing just the handle cannot fix the leak and common sense should tell you that.... try turning off the water to the diverter (thru access panel on opposit wall or main water valve for the home) and then replacing the stem or cartridge inside the diverter -- this is what controls water temp, pressure, and is responsible for any leaks you may have...
Aug 31, 2009 | Delta & Single Handle Shower Faucet
Water is leaking out my waste line when using recirculate.
Replace the internal "wagon-wheel" looking gasket inside the valve. Its job is to keep the water going thru the valve and ports the handle is set to and not leak out of the waste port.
Aug 08, 2009 | Hayward SAND FILTER, PRO SERIES
No hot water
if the leak is behind the handle take the handle off and tightn the packing nut, do not over tighten, as far as luke warm water is this with just one facucet on, they way these tankless water heaters work they are by gpm, gallons per min, if you have more gallons of water going thru the unit then it is designed for then it won't get hot, if your water pressure is to high going thru it will push it to fast thru the unit and won't get hot, your house pressure should be no higher then 75lbs no lower then 65lbs
Feb 25, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Water heater problem (no leak on floor)
It sounds like you might have scale buildup on the elements. If its a dual element unit it will ground it self out and it sounds like its boiling. constance usage of electricity, but no water usage. Drain it, and pull the element and replace the element.
Jan 17, 2009 | Water Heaters
Earthwise 1850 PSI Electric Pressure Washer Logo
308 people viewed this question
Top Earthwise Garden Experts
Steve Sweetleaf
Steve Sweetleaf
 Larry
Larry
Call Bill
Call Bill
Are you an Earthwise Garden Expert? Answer questions, earn points and help others
