Question about Vacuums
How to remive spin brush NVD Superline Dual Motor Vacuum Cleaner model WE 77000
2 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: I have a hoover steamvac
One cause is that the recovery tank lid isn't on correctly and not sealing. If there is a foam filter on the inside of the lid, make sure it has a 1/4 in. gap from the top of the lid. There is another filter, from the bottom, it has a red frame, pull it out far enough to clean it. May have a bad turbine, or the shaft on the top of the brush block broke off. You have a 1 years warranty on this, I would take it in to a warranty repair shop and get it repaired.
Posted on Aug 10, 2008
Vacuum cleaner brush won't work
Belt off or motor issues. Can't say without make and model.
Oct 01, 2017 | Vacuums
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Why did the brush roller stop spinning?
    With the cleaner unplugged, turn the unit over and look inside the opening where the brush is located. Do you see the clogging of the brush with lots of hair? If so, you will need to disassemble it to remove the hair. In any case, you will probably need to take off the cover to see if there is an obstruction jamming the brush. Also, check to make sure that motor for the brush is getting power. If there is an electrical cable on the outside connecting the brush housing to the rest of the vacuum cleaner, check if it is disconnected. When you have the cleaner on, do the lights glow? Do you hear the motor running? Try the above and report back.
    Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
    Why beter bar dosent spin while in the vaccum mode only in up right position ?
    Hello! The air pressure from the motor is most likely spinning the brushes in the upright position. This vacuum has a brush-roll on/off pedal located on the left side of the cleaner. To activate the brushes, power the vacuum on, recline the handle and then press the brush-roll on/off pedal. The brushes should begin to spin. If they do not the belt may need to be replaced. Hope this helps!
    Jul 12, 2014 | Hoover Vacuums
    Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
    Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
    1. Unplug cleaner from electrical outlet.
    2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
    3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
    4. Place ends of Rotating Floor Brush down into slots on sides as shown.
    5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
    6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
    7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
    If suggested solutions do not correct the problem, call:
    BISSELL Consumer Services 1-800-237-7691
    Monday - Friday 8 a.m. - 10 p.m. ET
    Saturday 9 a.m. - 8 p.m. ET
    Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
    The spinning brush isn't moving
    Belt may be off the motor spindle, with the vacuum off try turning the brush by hand, does it turn freely or can you feel the resistance of the motor?
    May 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    My brushes wo't spin on my spin vac dual v carpet cleaner
    Solution: Remove the clear plastic cover located in front of the brush control switch (I used a butter knife). Locate the small screen and remove the dirt and hair from it with your fingernail or an old tooth brush. Restore the cover and you should be good to go.
    Nov 22, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
    HOOVER DUAL STEAM CARPET CLEANER BRUSHES WILL NOT SPIN....MOTOR SOUNDS STRONG...
    There are three things to check:
    Is the switch on the hood for brush speed set to full, or may it be set to OFF?
    Remove the brush block from under the unit by pulling it down and unlatch each side. Is there a 1/4 inch square drive pin on one brush, about two inches long? It connects the brush to the drive mechanism.
    Lastly, the drive mechanism in the base may be bound-up, and not spinning. If so, the unit needs disassembled to repair or replace.
    Oct 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    Windtunnel dual v vacuum cleaner brushes do not rotate when the vacuum cleaner is turned on
    when you turn this model on, the only way to have the brushes turn is to move the brush control switch to on and then tilt the handle back. if all of this is ok but they do ot spin then check to see if you can turn them by hand with the machine off and unplugged. check the lint filter underneath the unit. if you cannot turn the brushes by hand then your issue is most likely the turbine. requiring shop service.
    Oct 17, 2009 | Vacuums
    M1300 i dirt devil brushes wont roll
    Ok I would say the belt burnt into if you can turn it on and the motor runs it is the belt . I would pull it apart and replace the belt.
    Feb 25, 2009 | Dirt Devil M130000 ''i'' Dual Cyclonic...
    Vacuums Logo
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
