Question about Rule 1800 H53SP-24 Swimming Pool Cover Pump
Doesn't shut off when the water is gone. - Rule 1800 H53SP-24 Swimming Pool Cover Pump
    Top Expert:
  • Rule Master
  • 4,292 Answers
Bad float water sensor
Posted on Sep 15, 2017
Where can I find the water valve shut-off for my kitchen sink
The sink usually doesn't have a shut off of it's own look on the side of your house ,the side closest to the meter & there should be a main water shut off valve for the house.
Jun 06, 2012 | Plumbing
My 99 expedition shuts off when I put it in reverse and shuts down when I have to stop fast at a red light. I have codes p0443 and p0441 on. Someone please help
P0443 code, EVAP system control purge control valve circuit failure, p0441 is related to p0443. if you fix it, both codes should be gone! to fix p0443-- Using a scan tool, command the purge solenoid to activate. Listen or feel for a clicking coming from the purge solenoid, If it doesn't click with scan tool activation, unplug the connector and examing the solenoid and connector for damage, water, etc. Then check for battery voltage on the feed wire with the key on. If you have battery voltage, then ground the control side manually using a jumper wire and see if the valve clicks. If it does, then you know the solenoid is working properly but there is a problem with the control circuit. If it doesn't click when you manually ground it, replace the purge solenoid.
Mar 22, 2012 | 1999 Ford Expedition
2005 touareg water in oil not head gasket; getting coollant error n=messages - fill it, only to get messages again about 4km later with coolant gone
water doesn't just evaporate it has to be leaking out somewhere, how do you know that the head gasket isn't blown ? it may be cracked or the engine block may be cracked or a seal is leaking,water doesn't disappear it has to be going somewhere, it might be a good idea to have the radiator pressure tested to find out just where the water is leaking from .....hope this helps.....cheers.
Sep 20, 2011 | 2005 Volkswagen Touareg
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
I have a Vaillant Combi boiler, (not sure of make, but its 10 years old),the hot water works fine and the bolier heats up the downstairs rads fine, but the upstairs ones have all gone off...have bleed them...
lost pressure raise pressure up 2 bar and bleed the rads keep topping up untill all air has gone from rads do this with the pump off, turn all your rads back on and follow what in said .
Aug 27, 2011 | Heating & Cooling
Fills with water and dont shut off
If your washer doesn't shut off the water when it is full. You have a bad sensor or water level set switch.
Jun 08, 2011 | Frigidaire Washing Machines
It was on and all of a sudden it just shut off and want come back on
Unplug the T.V. and hold the power button for 30 seconds. Plug it back in and see if it comes on. If it doesn't come on try using a different power outlet, if it still doesn't come on then the power supply may have gone bad and would need to be replaced.
May 05, 2011 | Televison & Video
Rule 1800 H53SP-24 Swimming Pool Cover Pump Logo
54 people viewed this question
Top Rule Pool & Spa Experts
Bill Jordan
Robco Water
Robco Water
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
