Dvd damage on arrival - Computers & Internet
Tip
The NASTY "CRC" Error ......Tackle IT
What does CRC(Cyclic Redundancy Check “error”) mean?
There are plenty of technical resources on the Web that discuss cyclic redundancy checks (CRCs). Most times you won't need to worry about this technobabble. That is, until one it day it suddenly appears and you think - what the hell does that mean? In simple terms, a CRC is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted. However, it does not mean all the data is lost forever. When data is transfered, it is usually in small blocks and each block is given a CRC value. If something goes wrong with the data between the time it leaves the source and arrives at its destination, the CRC sent at the source will no longer match the one that is calculated when the data arrives - this is when the cyclic redundancy check error will appear.
The most common time you will see the cyclic redundancy check error message is when trying to read data from a damaged CD or DVD. Just before it appears, your CD/DVD drive will probably grind and whirl away - your PC may also become a little slugglish.
Less frequent causes are the result of system crashes, and buggy software (hello Microsoft), incomplete downloads (often identified by the misleading message 'This is not a valid Windows file', 'This is not a valid win32 application' or 'Corrupt Zip file'). If this problem happens frequently with downloads, try using a download manager.
For CDs and DVDs, the problem is a little different. Normally, when CD/DVD drives get a CRC message from a disc, they try to read the disc again - hence the grinding sound. After several failed attempts, they give up and display the redundancy check error. The problem can be hardware (loose cables, failing drive), software or damaged media. In most cases checking and cleaning the disc is the easiest way to overcome the problem. If different clean discs produce the same error, it is likely to be a hardware issue (check the discs in another drive). Another common cause of these errors is poorly burnt CDs and DVDs - especially those that had numerous or severe buffer underuns. USB burners suffer from this problem when the burn speed is too high (generally above 4X-8X)
If the discs are damaged, you'll probably need a recovery tool to get back your data. CDCheck 3 will work for CDs and DVDs. First it will check the media, and then you have the option to recover the files. It's free for personal use and has saved many people heartache when it comes to recovering lost digital images and videos from damaged CDs.
on Dec 22, 2009 | Computers & Internet
How dod I get a replacement for a disc which arrived with a crack
contact your supplier and talk with them about a replacement disc
Oct 18, 2015 | Televison & Video
It has arrived with broken wing May I try to stick it and use for garden and return later for replacement? Bought from Prime arrived late and badly packaged large box but dragon in corner?
This page is not the page to make this enquiry
if you do anything to it or keep it, you accept any damage and will negate any claim for warranty or replacement
Take photos of packaging and of the broken item and inform the supplier immediately that it arrived badly packed and damaged and that you want a replacement sent immediately or a refund of the money for the item
the supplier has insurance against damage in transit so thee will be no legal objection for what you want
May 28, 2015 | Cars & Trucks
Recently received a cassette player - it is completely smashed up and broken - where do I return it?
why did you accepted it? do you have proof that arrived in that condition? is there internal or external damage? do you have any proof of delivery in that condition?
if any of the above - delivery insurance will cover it (from delivery company),
if you have proof of internal damage and arrival in that condition - place of purchase is responsible,
if no proof of any of the above - rubbish bin is fine location...
Mar 29, 2015 | Audio Players & Recorders
Can I return a shipped item to store for credit? When it arrived it was damaged.
I would contact customer service first and see what their policy is for sending back damaged items done in shipping. Rich
Dec 21, 2014 | Computers & Internet
I can't read Asian DVD. My wife arrive from Thailand and want to read her Original DVD. Have you got sollution?
Please check in the manual which region code (which is displayed at back cover of DVD) can be played on your DVD player. If the DVD brought from Thailand carries the same there should not be a problem but if it is different then it cannot be played. This must be the reason of not reading/playing. Solution lies that you should have a multisystem DVD player
May 03, 2010 | Philips DVD757VR DVD Player/VCR
Disk player won't open
Was there damage to the case after shipping? It would seem so due to display and other functions not working. Your remote has no open/close function. That leaves two options; remove the covers and try to manually remove the disk (which I don't suggest) or have the unit serviced. I found no manual release for the Disc tray, which some units have, but even if it did that wouldn't solve your problem. I would guess you have broken wiring or a damaged/cracked circuit board on the front panel.
Nov 30, 2017 | Panasonic 5 DVD/CD Micro System with MP3,...
Gateway M-6848 arrived with vista home. used
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Jul 14, 2009 | Philips (JR4DVDRWK/00) DVD+RW Burner
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
