Question about Xerox WorkCentre XD130DF Laser Printer
L6 Code xd130df L6 code - Turned on the Xeorx copier and now it is giving me a L6 code. I did the on off try and that did not worK. Please help, cannot afford a new copier.
    Problem Solver:
  • 19 Answers
The Laser's Polygon Motor has failed to reach proper speed in the allotted start up time.
Replace the polygon/laser assembly.
Posted on Jun 19, 2009
WHAT IS THE L6 CODE
L6 is a motor lock code relating to a paper cassette. There should be a 2 digit code after the L6. Please tell me the model sharp and the 2 digit code and I can help more.
Apr 02, 2015 | Sharp AR-M205 Copier
XEROX XD130DF HAS ERROR CODE L6 HOW DO I FIX IT
An L6 usually means the motor that spins the mirrors in the laser unit has failed.
You can try unplugging the machine, removing the back cover and unplugging and reseating the plugs on the main circuit board, if that doesnt work, then there is probably a 90 percent chance the laser will need to be replaced. Not an easy job to replace. You can try looking on E-bay or other online part sources. But used really isn't the way to go on a laser and it would be at least $200 to purchase one, wish I had better news .
Jan 19, 2010 | Xerox Office Equipment & Supplies
I have a little used Sharp AL1000 copier. I recently turned the copier off when we had an electrical storm and power glitched a couple of times. Now that I have turned back on, a code L 6 comes up. The...
It is the old machine.I try to help you:the L6 code refer to paper tray check the motor and the sensor in this casette,is pure mechanical problem.To enter in the service code try :
C-0-0-C or
C-interupt key-0 - interupt key
and if remember the 97 or 98 setting code refer to the rotary casette size setting and the rotary casette paper sensor test adjustment.
Aug 27, 2009 | Sharp AL-1000 Copier
The L6 code is flashing on my copier
No you can't, it is the polygon motor not rotating. It is inside of the Laser unit. You should replace the polygon motor. The part code is RMOTN0028QSZZ. It will cost you about US$ 80
Jun 04, 2009 | Sharp AR-160 Copier
L6 code on a Xerox XD130 DF
Yes, and L6 means the main board is not detecting the operation of the motor that runs the mirrors in the laser.
In order of probability , the laser is bador the main board.
Jan 14, 2009 | Xerox WorkCentre XD130DF Laser Printer
L6 sub 10
Hello sir; I'm not sure the error code can be reset or not but we can give it a try, the easiest way just turn power on and off if don't work follow following steps;
1, press "#", "interupt" "c" "interupt"
2, enter 14 then press start.
Jan 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code L6
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Dec 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
I need help with workcentre XD130df
J2 means the life of the drum has expired.
If replacing the drum does not fix it let me know.
J2 means the drum has met it's 18,000 page life.
Apr 04, 2008 | Xerox WorkCentre XD130DF Laser Printer
Mobile phone
It is probably your network provider's code for the sim card. Try contacting them and see what they suggest. Alternatively your phone may bhe locked. Please give some more info on the code it is asking you for.
Mowcius
Dec 11, 2007 | Motorola Mobility L6 Cellular Phone
Xerox WorkCentre XD130DF Laser Printer Logo
573 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
