Question about Nikon Coolpix S2700 16 Megapixel Compact Camera - Purple - 2.7 LCD - 6x Optical Zoom - 4608 x 3456 Image - 1280 x 720 Video - HD Movie Mode
When I try to download photos from my S2700 to my computer, via a USB, the computer does not recognise the camera and the charging light flashes rapidly when the cable is attached and camera turns its
When I attached the camera to my computer via a USB cable, the computer does not recognise the camera, When the cable is attached the camera turns itself on, as it should, but then the charging light starts flashing (fast, showing it is charged) and the photos can not be lcated.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Posted on Apr 22, 2014
5 Suggested Answers
  • 175 Answers
SOURCE: can't download to computer
You need to go to the tools menu and change USB fro PTP (Picture transfer protocol) to MASS STORAGE. PTP is only used if controlling camera from computer.
Posted on Oct 24, 2010
  • 196 Answers
SOURCE: My Nikon S4000 (black) won't charge. I've tried
Follow this order:
when plugging in the camera and then plugging into the compuer does the computer recognise it? If not this is either a bad cable, or not an active USB port, or something has gone wrong interanlly with the camera. Internal can be anything from bad voltage chip to bad battery. But some people have put the battery in backwards or with the positive terminal the wrong way. Double check that this has not happened, as anyone could have done it, unless you live alone. Try another computer and see if it recognises that camera if so the cable is good and you can continue to trouble shoot in other areas.
Posted on Mar 11, 2011
  • 147 Answers
SOURCE: My Nikon S4000 (red) won't charge. I've tried
The battery itself won't charge in-camera like a cell phone-- you'd need to remove the battery and plug it into the supplied charger (EH-68P). You may have an ac adapter for the camera that basically would just be used to power the camera without a battery or for long periods of time without relying on the battery. It wouldn't be used to charge the camera.
Posted on Mar 12, 2011
russ_hill007
  • 4018 Answers
SOURCE: fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Posted on Mar 24, 2014
When I try to transfer my photos from the samsung digital camera ES70 to my computer a message come up saying "USB Device not recognised". Why?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Aug 26, 2013 | Zeikos Samsung ES70 Digital Camera...
L55 not recognised by windows7
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Oct 19, 2012 | Fujifilm Finepix L55 12 Mp Digital Camera...
When i try to download my photos off kodak 9.2 mp (m320)camera it doesn't recognise the device on my laptop but when i charge it it works.what might be the problem?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Feb 01, 2011 | Kodak EasyShare M883 Digital Camera
Mac won't recognise canon drive
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to a Windows computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this camera photo recovery software
http://www.asoftech.com/apr/
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Oct 11, 2009 | Canon EOS 40D Digital Camera
Trying to transfer but not being recognised
You don't need a driver.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Dec 24, 2008 | Kodak EasyShare M873 Digital Camera
Computer won't recognise my Nikon d60
dont bother to connect camera to pc..just use the SD card reader...either external usb one or laptops internal one
Dec 19, 2008 | Nikon D60 Digital Camera
Photo software
" i'm told the f drive has been deleted ???????????????
it seems that your computer is not recognising the camera. How do you connect it via USB . check the USB cable or the installation / driver software of your camera. and if every thing is ok and still the computer is not recognising the camera you can transfer the images thru card reader.
Feb 14, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Computer won't recognise camera to download images
** Problem Solved **
I found it wasn't the camera entirely to blame. I tried another USB cable on another pc, and although the camera was doing the same thing as my problem, the computer recognised the camera as new hardware, and asked me how to access the pictures. So I was able to get the pictures from the camera to the computer, and then saved them on to my Kingston flash drive. So taking the flash drive to my daily PC, I plugged in my flash drive via a USB extension lead, and discovered that would read either... alarm bells rang. So I unplugged the lead, and put the flash drive straight into the computer direct. The computer recognised it immediately. So plugging in the extension lead again, and the flash drive, it read this now. So I tried the camera, and it recognised it.
So I don't know exactly what the problem was, but it was solved... saved me a lot of running around and money ;)
Feb 13, 2008 | Cameras
Nikon Coolpix S2700 16 Megapixel Compact Camera - Purple - 2.7 LCD - 6x Optical Zoom - 4608 x 3456 Image - 1280 x 720 Video - HD Movie Mode Logo
44 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
